There are a lot of things we do not understand; one expert seems to think fracking could be the cause https://thetyee.ca/Analysis/2022/11/21/Taking-Fracking-Quakes-Seriously/
I have to reject your idea that there are no contacts being made., I am active on HF daily. As the day progresses some bands fade out and others pickup. The bands are active this weekend with several contests. There is a web site that shows realtime contacts being made by showing lines between the two stations and if you hover over a station you get their call and location. You can see this for free. It is interesting to watch how the bands progress as the day progresses. Turn on the Grey Line for additional info. You can customize the display using the drop down boxes. The site is: https://www.dxmaps.com/spots/mapg.php?Lan=E On contest weekends you can see the number of contacts being made here: https://contestonlinescore.com/ you need a free account so create one. The information is only shown active contests. There is a drop down list to select a contest. 73, Rich wb4ehg
You cannot argue with anyone who thinks "The Science is settled" Science is never settled because if one believes it is they are practicing religion instead. There is so much evidence in the magnetic field declines today trying to argue it is futile as the people your arguing with. I think the rush on to renumber runways is the need to align them with Hogworts over time.
My personal thoughts about Davidson is he is going off the rails because so many treat him like the messiah. But a few facts remain like they have been published and cited multiple times in respected journal's. Much of what they are saying is sound. My issue is his trying to put a time frame on it and telling people to move to certain locations. That is annoying as all get out. Your gaslighting serves no real purpose other to say you believe anything so called authority tells you. Far better to listen to all sides and make a rational decision than do the Snopes dance to reinforce your lack of understanding the subject matter material's.
You really believe that and say it openly? OK, Magnetic fields play a substantial part in weather and it's changes. Again published science with NASA and The ESA publishing on it among many leading Academics. Do some home work soon please. And probably look into Greta's family tree and those around her. It is very enlightening but no one dares say it.
Multidecadal variation of the Earth’s inner-core rotation | Nature Geoscience Yup. New. 1/23/2022. Not marked as peer reviewed. Core of Earth has stopped rotating. Could be interesting..
Yes. Will be an interesting time upcoming as the cycle improves and the magnetic field declines. Fortunately with molten iron core, Earth will always have a magnetic field. If we didn't we'd be like Mars and eventually the solar radiation would disintegrate our atmosphere.
geof (stanford.edu) Liu, Jerry Z. Ph.D. ( see also Superconductive Origin of Planetary Magnetic Fieldss (stanford.edu) for Jerry's other papers) Abstraction Earth’s magnetic field shields life on Earth from the harmful solar wind. However, its origin is not well understood. The dynamo theory is usually employed to explain the origin. However, it cannot account for the magnetic fields on other planets, especially those with cooled cores. In light of new understandings of superconductivity, a new hypothesis is proposed in this study to provide a general mechanism for the origin of planetary magnetic fields. The “unified theory of low and high-temperature superconductivity” suggests that superconductors are the ordinary state of matter and are common at high pressures. As pressure increases deep into Earth, superconducting substances likely exist under the mantle. Driven by the rotation of Earth, the floating superconductors on the outer core accumulate towards the equator and eventually assemble into a belt looping around the core under the equator, producing a resistance-free path for currents. Earth's magnetic field was created by a Mesnner-like effect in the Sun’s magnetic field. The field compensates Sun’s field inside and superimposes it outside of Earth. Without electrical resistance in the superconductor belt, currents loop indefinitely under the equator, maintaining the geomagnetic field. Convections in the outer core disturb the loop and occasionally break its continuity, causing polar wandering and paleomagnetism discontinuity. As the loop resamples each time, the polarity of the new field may be created in a different direction depending on whether the north or south pole is tilted towards the Sun at different seasons, resulting in a magnetic reversal. Superconductors may also be responsible for the magnetic origin of other planets. As planets cooled down, the superconductors froze inside the planets. Some might survive various celestial events throughout the planet's history, even with significant orbital changes, which explains the large angle and offset between the magnetic dipole and rotation axis of both Uranus and Neptune. Full monograph at link above. Not marked as peer reviewed, it does have a revision history, which could indicate such a review. Enjoy.
FWIW - Ben really did go to school Education: Juris Doctorate – Capital University Law School 2011 The Supreme Court of Ohio, Summer Clerkship, Justice Pfeiffer BA Economics – Denison University 2006-2008 Golf Team, 2007 All-Conference Team Economics/Meteorology – Penn State University (Schreyers’ Honors) 2003-2005 Intramural Golf Champion 2004 Like anything on the Internet, you get to make your own choice on who you wish to believe or not.
