ad: CQMM-1
All About Sporadic-E Propagation
Discussion in 'Amateur Radio News' started by N5HZR, Jul 15, 2019.
  1. N5HZR
    N5HZR Premium Subscriber QRZ Page
    Sporadic-E propagation allows us hams to send and receive signals over great distances, through the ionosphere during brief and crazy circumstances. Doug Speheger KC5JUS has been watching this happen for years, and he has tracked many sporadic-E paths over this time. Doug gave a presentation at a recent South Canadian Amateur Radio Society (SCARS) meeting and this video will help you understand this phenomenon a bit better. Doug talks about 2 meter, 6 meter, and broadcast band paths.
    We hope you enjoy it as much as we did...
    SCARS is based out of Norman, OK, and is online at https://w5nor.org
    VK3GOR, M1WML, KA0HCP and 2 others like this.
  2. KD2GIY
    KD2GIY Ham Member QRZ Page
    Sporadic-E propagation is a switch in ARRL headquarters in CT, that they turn on only during contesting.
    AK4AM, K4MOE, AB9TX and 15 others like this.
  3. PP8DA
    PP8DA Ham Member QRZ Page
    Very interesting presentation, unfortunately in my area 6 m appears not to work. I live 3 deg S, 60 deg W. Never heard anything near the equator.
    M1WML likes this.
  4. KQ6XA
    KQ6XA Ham Member QRZ Page
    Great to see a good video on Sporadic E (Es).
    Celebrate the season of Sporadic E!
    It is a special kind of propagation that happens randomly during night or day.
    There is not much Sporadic E scientific study, and some aspects of it are still not well understood.
    Current studies have pointed to a fascinating source of Sporadic E: meteors!
    • It seems to form, at least partially, due to high altitude (thermosphere) meteorite ablations.
    • As tiny meteorites burn up in the upper atmosphere of earth, the tiny particles disperse into the earth's thermosphere.
    • The meteorite particles tend to collect in "reflective clouds" made of iron ions (and other elements) under certain conditions and temperature differentials.
    • The clouds of Sporadic E tend to accumulate in between layers of wind shear up around 70 miles high (112km) in the E layer.
    • The Sporadic E clouds are most common at mid-latitude, and are not usually found in equatorial or polar regions of the earth.
    Sporadic E provides strong signals, even with low power.
    Es is somewhat independent of the normal 11 year/ 22 year Solar Cycles that affect F layer propagation.
    It is great for upper HF and lowband VHF contacts, to distances of about 200 to 1500 miles.
    The best bands to work Es are in the range of 14 MHz to 70 MHz.
    You will find 15 metres or 10 metres are particularly good.
    If you tune to 27385 kHz LSB (CB 38 LSB) and listen for active CB operators, you will find that they are usually the first to catch a Sporadic E opening. If you hear a lot of activity on that frequency, it is likely that a big Es opening is happening.
    Factoid: It is now legal to talk long distance (skip) on CB . :)
    The most recent studies have relied on LEO satellites that received 1 GHz GPS signals and recorded variations (phase changes from reflection or distortion) caused by E layer ionization.
    But, Es has much stronger effects in the high HF and low VHF range (20 MHz to 100 MHz).
    Sporadic E has traditionally peaked in North America in June/July/August.
    During June of 2019 the Sporadic E happened almost every day for a month.
    The Sporadic E seems to be happening earlier in the year recently, perhaps due to climate changes or other factors.
    K7GYB, K8XG, KX1MAD and 6 others like this.
  5. NL7W
    NL7W Ham Member QRZ Page
    Nice presentation. :)
    M1WML likes this.
  6. W1UT
    W1UT Ham Member QRZ Page
    This is an interesting presentation. I too have followed E-skip for many years including from both sides of North America. I used to live in Vermont and Maryland and we had E-skip propagation regularly each summer and sometimes at other times of the year as well. I now live in Utah and have been here for 6 years now. I have HF, 6m and VHF/UHF capability. I live at about 6000 feet elevation in a mountain valley but the mountains are still miles away. It is exceedingly rare to hear any E-skip in this part of the country. I check DXmaps regularly and see all of the activity usually right over the top of me. Do I hear anything? Very very rarely and even then the signals are weak. So ... I ask, why? What is so different about this location? One would think with the higher elevation I would hear even better, but this has not been the case.
    M1WML likes this.
  7. M0YRX
    M0YRX Ham Member QRZ Page
    N6SPP, M1WML and KQ6XA like this.
  8. KQ6XA
    For Sporadic E to work well, the ionized "cloud" needs to be about 400 to 700 miles away from you, and mid-way to the station you want to communicate with.
    I worked Utah in June during the Field Day Sporadic E opening.
    So there is, indeed, sometimes an Es path to Utah!
    Some Sporadic E researchers appear to have found evidence of high altitude mountain wave turbulence affecting Sporadic E.
    KF4ZKU and M1WML like this.
  9. NI4Y
    NI4Y Premium Subscriber QRZ Page
    I worked several PY while I was in P4 and the 6m Beam was fixed to the east coast of NA. Off the back I worked a few short hops on 6 and 10m. It is very much an activity issue in SA I Tune to 50.313 and leave it on while you work you will be surprised to hear a blip every now and again on FT8.
  10. K8ZT
    K8ZT XML Subscriber QRZ Page
  11. KI6PMD
    KI6PMD Ham Member QRZ Page
    I love 6# meters ! When its open it is MAGIC ! when its not its TRAGIC ! so far we have have a few real nice S2 openings. See you on 6# 73'Phil KI6PMD..
  12. AC8SW
    AC8SW XML Subscriber QRZ Page
  13. AC8SW
  14. KJ8O
    KJ8O Ham Member QRZ Page
    My furthest station on FMBC (3 meters) was KGNZ 88.1 Amarillo Texas to Detroit Michigan at approx. 1,400 miles in July 2006. The opening was so big, it was even mentioned in the QST World Above 50 MHz article. The station was so loud, I though I was hearing a local, on my car radio no less.
    KF4ZKU likes this.
  15. KJ8O
    Correction, Abilene, not Amarillo.+
ad: portazero-1
