ad: AntWorld-1
More Power For 2 Meters!
Discussion in 'Amateur Radio News' started by WJ6F, Jul 17, 2020.
  1. WJ6F
    WJ6F Ham Member QRZ Page
    If you would like more power for 2 meters, especially if you do 2 meter SSB or CW then check out the Mirage B 5018 G 2 Meter Amplifier! This 160 watt amp can really push your signal! The Mirage B 5018 G amplifier doesn't take up much room and runs quiet! You can also use the Mirage B 5018 G for tropospheric ducting!
    IW2NTD, KG4BFR, N2JAI and 2 others like this.
  2. KA8VNG
    KA8VNG Ham Member QRZ Page
    I have both a B108 & B310g, love them both for those extra s units & band opening's.
  3. W0MUD
    W0MUD XML Subscriber QRZ Page
    I use the B-34-G for my POTA activations. Its amazing what that little 35w amp does on 2m weak signal with the Elk Log Periodic. Fantastic amplifiers. The 160w version would be amazing in the shack.
  4. K0WJ
    K0WJ Platinum Subscriber Platinum Subscriber QRZ Page
    "You can also use the Mirage B 5018 G for tropospheric ducting!"
    As opposed to the competitor's amps that can't be used for tropospheric ducting??? :):):)
    KC3IGJ, KG7HVR, KA4TMT and 4 others like this.
  5. AK9S
    AK9S Premium Subscriber QRZ Page
    More Power for 2M?
    I recall Mirage selling 2M amps with the same power rating for at least 30-years.
    Suggest the title be changed to Same Power for 2M, LOL.
    Of greater interest would be information concerning any improvements to this particular amplifier over predecessors.
  6. W0AQ
    W0AQ XML Subscriber QRZ Page
    I have used an HT at one watt for that too, even though such activity was not certified by the manufacturer. :)
    N7ZUM likes this.
  7. PA5COR
    PA5COR Ham Member QRZ Page
    Still have my homemade 2 x MRF 247 class a/B amplifier doing 160 watts, build that one 33 years or so ago from the motorola handbook.
    KG7HVR, KX0Z, KG4BFR and 1 other person like this.
  8. VK2JI
    VK2JI Ham Member QRZ Page
    Unfortunately no longer manufactured but you can still get them on the second hand market if you "really" want more power for 2m - it needs 100w drive though - so TS200, IC9700 etc. as driver rig.
    Crazy power level for 2 metres though.
    WA6MHZ, KG4BFR and AK9S like this.
  9. VE2JN
    VE2JN Ham Member QRZ Page
  10. KG4BFR
    KG4BFR XML Subscriber QRZ Page
    I have in my Mobile Rig a Original Pre MFJ .....Mirage Communications Equipment Inc. Morgan Hill California B1016 IMG_1125.jpg
  11. KK6ILV
    KK6ILV Premium Subscriber QRZ Page
    I also have a Mirage amplifier, B-1018-G in my shack with a 10 element Cushcraft 148-20T works well together. DSCN3249.JPG
    KK4CUL likes this.
  12. N8ZI
    N8ZI Ham Member QRZ Page
    Numerous 2m amplifiers are available, not just Mirage. Mine are RF Concepts and built like a rock. Everything from mild to wild. I believe Lunar Link still produces full legal limit ++ amps running a pair of 3CX800A7's. Another company sells pallet kits that produce 1KW on 2m.
    A wise, less expensive option is to just put a better antenna up higher. You'd be surprised what an additional 10' of height will help you achieve.
    Can't forget studying the propagation forecasts. William Hepburn "tropospheric ducting forecast" works quite well.
    My furthest 2m QSO was from MI down to eastern Mississippi only using 75w and a 6 element yagi I built.
    KA4TMT likes this.
  13. G1MHU
    G1MHU XML Subscriber QRZ Page
    why is this an allowed post?
  14. WA6MHZ
    WA6MHZ Ham Member QRZ Page
    why wouldnt it be? Stateside hams can do 1500W output on 2M!
  15. W7UUU
