ad: TinyPaddle-1
HF Mobile Install (Ram 2500)
Discussion in 'Amateur Radio News' started by WJ6F, Jun 6, 2020.
  1. WJ6F
    WJ6F Ham Member QRZ Page
    Here's how I did an HF Mobile Install In A Ram 2500! I also show you where I bonded the truck to get a better more efficient ground plane. Most of what is used in this HF Mobile Install is from my last vehicle. This project ended up being easier than I had originally anticipated. The items I installed are the Yaesu FT-891 and the ATAS 120A. I have heard people trash talk the ATAS 120A, but I have been told the key to the ATAS 120A is grounding.
    KL5PF, WP4OTO, N3DAW and 10 others like this.
  2. KM4UVY
    KM4UVY Ham Member QRZ Page
    What kind of mount do you have the radio on? Cup holder or?
    Thanks I have a 1500 looking for the best way to mount the radios.
    Joe KM4UVY
    KJ6LDJ and WJ6F like this.
  3. WV4M
    WV4M Ham Member QRZ Page
    Great post. Thanks for sharing.
    WJ6F likes this.
  4. WJ6F
    I used a Lido cup mount from Ham Radio Outlet, and a PVC 4"-3" reducer for drain systems spray painted black.
    KM4UVY likes this.
  5. JF1IRQ
    JF1IRQ Ham Member QRZ Page
    地面が正しく設定されています。
    問題ありません。
    JF1IRQ From Japan
  6. KD2BBC
    KD2BBC QRZ Lifetime Member #587 Platinum Subscriber Life Member QRZ Page
    Everything you done is correct I’m not saying you did anything wrong but bringing some advise from past experience you did wonderful with your install
    from my personal experience I DID the same type of install with the same ANTENNA mount turned out i had that tail light cracked because of that mount lip over time opening and closing
    so guys beware of that small lip from that antenna mount this is a big possibility that it might crack your tail light
    best to bend it out a little bit to avoid any contact with your tail light .
    that’s all
    thanks and 73
    WJ6F and W9AWX like this.
  7. W4BSS
    W4BSS Platinum Subscriber Platinum Subscriber QRZ Page
    Nice video!! The ATAS 120A is a decent little antenna. I owned one for many years along with a FT-100D and made many DX contacts while driving using only 100 watts. Grounding is key but weatherproofing of the ATAS 120A is very important. I added a little blob of black Permatex silicone to the slit in the rubber boot where the whip passed through on top of the antenna shaft. My ATAS stayed dry for years but many hams found their ATAS 120A had turned into a rain gauge due to water intrusion.
    W4BSS
    K9EZ likes this.
  8. KD7SV
    KD7SV Premium Subscriber QRZ Page
    What model Blue Sea Fuse block did you use? Looking at the video and their website, not sure I can tell which one it is.
    Dan
  9. W4KVW
    W4KVW Ham Member QRZ Page
    I hope you have much better success with the ATAS 120A antenna than I did with a Yaesu FT-857D.It by far is the WORST HF mobile antenna I have ever used or owned.Hamsticks,Hustler,DK2 Screwdriver & the TARHEEL II all blew it away on transmit & receive & none of them ever started re-tuning in the middle of a QSO.All of those antennas were used on the same mount on the same mounting location.You could never give me another one even for FREE if I'm required to keep & use it or the 857D.I have considered the 891A as my next HF/6 meter mobile since ICOM thinks every radio should have a Touch Screen but I would purchase another TARHEEL II if I go that route.
    Clayton
    W4KVW
    KT5OT and N4GST like this.
  10. W4KVW
    I forgot to mention that the ATAS 120-A stayed Full of water every time it rained & it rains a lot here in Florida.
    Clayton
    W4KVW
    KT5OT and WJ6F like this.
  11. WJ6F
    Excellent advice! I did check and I do have a space in between the light and mount. I just hope it is far enough if some one gets over zealous closing the tailgate.
  12. WJ6F
    I take mine of when we get rain
  13. WJ6F
    I used the Blue Sea Systems 5025 ST Blade Fuse Block. I got it off amazon.
    KD7SV likes this.
  14. W4KVW
    Mine would stay Off very often if that were the case here.I prefer one I can leave installed. {:>)
    Clayton
    W4KVW
    W5CJA likes this.
  15. KD2BBC
    Lol well let
    Just hope for the best ... I was so pissed off when mine cracked my tail light it was not a cheap fix and nowadays tail lights are expensive to replace
    Thanks for taking notes
    nice install tutorial
    I love it
    KB6M and WJ6F like this.
ad: Halibut-1
