ad: W5SWLcom-1
DPØGVN WSPR Beacon in Antarctia is operational
Discussion in 'Amateur Radio News' started by DF2NU, Jan 18, 2018.
Tags:
  1. DF2NU
    DF2NU Ham Member QRZ Page
    On January 15 in the afternoon hours, the multiband receiver of the new permanent WSPR beacon DPØGVN in Antarctica was put into operation. It is active from the German research station "Neumayer III" of the Alfred Wegener Institute for Polar and Marine Research. The installation is part of a scientific project of the Technical University of Munich in cooperation with the University of Bremen and the German Amateur Radio Club (DARC).
    The beacon is still under test and will be shut down occasionally for more configuration and optimization
    of antennae and software before it can be mounted to the final installation site in a few eeks. Currently,
    there are three radio specialists at the research station, all beeing HAM operators and DARC members
    (Felix DL5XL, Matthias DH5CW, and Daniel, DL1SU).
    The technology used consists of a WSPR multiband receiver based on a Red Pitaya mini computer, it can simultaneously monitor up to eight HAM bands from 160m to 6m and feed several hundred receive reports per hour into the WSPR-Net. Meanwhile, the 5 Watt multiband transmitter has also been commissioned, working into a 5m Procom vertical antenna matched with a network.
    The first operating results have positively surprised all project participants. After a few days in service,
    DPØGVN has received several tousand beacons spots already. This is due to an extremely quiet location, far
    from any human civilization and man-made noise sources. The beacon project in Antarctica was initiated by
    two professors, who are also radio amateurs. One is Prof. Dr. med. Ulrich Walter, DG1KIM, scientific astronaut
    of the ESA and professor of space technology at the Technical University of Munich. Also involved is the
    well-known SDR specialist Prof.Dr. Michael Hartje, DK5HH, from the University of Bremen, who takes care of
    the software solutions.
    The DARC is closely involved in the project, as the worldwide community of radio amateurs allows a "swarm project" in order to generate the database for systematic scientific evaluation of the propagation paths in polar regions. The devices for this scientific project were buitl by a group of volunteer German radio amateurs.
    K4AGO, AC7DD, W2VW and 10 others like this.
  2. M0XMX
    M0XMX XML Subscriber QRZ Page
    Happy to be heard by this beacon 11,000+KM on 10W from United Kingdom. IO92et M0XMX
    K4AGO, AC7DD, W2VW and 2 others like this.
  3. MW1CFN
    MW1CFN Ham Member QRZ Page
    Even happier my daughter was heard on 0.2W (actually measured as being 172mW) from Wales, using just a field-deployed vertical and WSPRlite by a lake:
    2018-01-17 21:42 MW6PYS 14.097156 -26 0 IO73ug 0.2 DP0GVN IB59uh 13787 182
    2018-01-17 21:38 MW6PYS 14.097156 -23 0 IO73ug 0.2 DP0GVN IB59uh 13787 182
    2018-01-17 21:30 MW6PYS 14.097156 -19 0 IO73ug 0.2 DP0GVN IB59uh 13787 182
    2018-01-17 21:26 MW6PYS 14.097157 -19 0 IO73ug 0.2 DP0GVN IB59uh 13787 182
    2018-01-16 21:10 MW6PYS 14.097154 -23 0 IO73tj 0.2 DP0GVN IB59uh 13801 182
    2018-01-16 21:08 MW6PYS 14.097154 -25 0 IO73tj 0.2 DP0GVN IB59uh 13801 182
    2018-01-16 20:40 MW6PYS 14.097154 -29 0 IO73tj 0.2 DP0GVN IB59uh 13801 182
    K4AGO, MM0XXW and W2VW like this.
  4. G0RQQ
    G0RQQ Ham Member QRZ Page
    Heard their beacon on 10MHz in the early hours of the morning of 18th Jan. No other signals decoded at that time. On the evening of 18th, heard them again and they reported my 5 watt signal again on 10MHz. Antenna is 20m-long wire in horizontal vee, about 1.5m above ground.
    Keith G0RQQ
    Lincoln
    K4AGO likes this.
  5. N4ADK
    N4ADK Ham Member QRZ Page
    Ham not HAM. Ham is not an acronym :)
    K4AGO and N5XKG like this.
  6. K0PIR
    K0PIR Ham Member QRZ Page
    Nice!
  7. DL6BCX
    DL6BCX Platinum Subscriber Platinum Subscriber QRZ Page
    Great project. Best wishes and i hope all will run fine.
    By the way.....with my additional SWL-call DE6BCX in January 2017 i sent 100 SWL-reports listening to WSPR beacons, one year later in January 2018 only five (!!!) SWL-cards were answered. Not so much, what a pity.
  8. GM4BRB
    GM4BRB Ham Member QRZ Page
    I could pick a flea with you here ... in jest.
    Holloman Aerospace Medical Centre
    ... after which 'Ham' the eponymously named US Space Chimp (see Avatar)
  9. K0PJS
    K0PJS Ham Member QRZ Page
    I was heard on 4oM in the evening earlier this week. Very cool!
    K4AGO and AC7DD like this.
  10. NU4R
    NU4R XML Subscriber QRZ Page
    A "WHAT-o-NYM?!?"
  11. OZ7NV
    OZ7NV Ham Member QRZ Page
    From OZ7NV
    The last two nights i was heart on 60m. I am running 5Watt in a magnetic loop antenna.
  12. KC5NOA
    KC5NOA Ham Member QRZ Page
    Does this beacon have a frequency I can actually tune too or I just look amelessely for a beacon all over hf spectrum?
    K2WH likes this.
  13. G0RQQ
    It’s a WSPR Beacon, so you require the WSJT software running on your computer to decode it. With regard to frequencies, they are indicated in the software for each band.
    Regards,
    Keith G0RQQ
  14. K2WH
    K2WH Premium Subscriber QRZ Page
    Agreed, I do not see where there is a frequency listing ??????
  15. K2WH
