ad: py7rp-1
Did I Save Some Money?
Discussion in 'Amateur Radio News' started by KM9G, Oct 27, 2021.
  1. KM9G
    KM9G Ham Member QRZ Page
    KE0QKF, N5XMV, N7BWB and 11 others like this.
  2. ZS1SBW
    ZS1SBW QRZ Lifetime Member #505 Platinum Subscriber Life Member QRZ Page
    yawn
    AE0Q, NG0L, KB2HSH and 9 others like this.
  3. WA6VVC
    WA6VVC Ham Member QRZ Page
    Probably saved a little by not using the large lugs for the inside connections.
  4. KC2PMM
    KC2PMM Premium Subscriber QRZ Page
    Does it really matter?
    KE0GXN, KS0FD, HB9EPC and 2 others like this.
  5. KF2YD
    KF2YD Ham Member QRZ Page
    Why is Amazon sensoring the bad reviews ?
    DL1RAS likes this.
  6. N7ITA
    N7ITA Ham Member QRZ Page
    Because they are unethical :( do a little research into Amazon you’ll see.
    DL1RAS, WA7DUH, W8BBM and 3 others like this.
  7. 2E0TWD
    2E0TWD Ham Member QRZ Page
    Fawn
    ZS1SBW likes this.
  8. W9MDT
    W9MDT XML Subscriber QRZ Page
    I have built several of these, found most of the hardware and wire(used thermastat wire instead of enameled) at a big box hardware store , sourced my toroid and pl-259 elsewhere. Used a 4x4x2 outdoor junction box. They work great with a tuner.
    KN4IFI, XE1FFZ, W5HEH and 2 others like this.
  9. MW1CFN
    MW1CFN Ham Member QRZ Page
    OK for the money, I suppose. But in rainy environments, it will definitely leak water and see condensation form. But you can grease the connections up to limit ingress, and I would always drill a modest hole in the lowest point of the box, however it's mounted, to allow moisture out.
    KC1DR and W5HEH like this.
  10. W3AMT
    W3AMT Ham Member QRZ Page
    I would make my own. I would never buy from Comrade amazon!
    KN4IFI, DL1RAS, KB7RWA and 3 others like this.
  11. W1BR
    W1BR Ham Member QRZ Page
    Nope. Far cheaper on the auction site for the same item.
  12. K9EI
    K9EI Ham Member QRZ Page
    I think half of the stuff in the "kit" is unnecessary. Just get the wire and a ferrite core with a known value, and spray it with flex-seal. I made a 64:1 with a type 52 core for $10.......
  13. NJ3T
    NJ3T Premium Subscriber QRZ Page
    Hi,
    If you build a random length end fed wire then you could use your kit to build a 9:1 balun for it but the EFHW needs a 49:1 transformer to work. The half wavelength wire has a very high impedance on it's end and requires the 49:1 to bring it down to match your 50 ohm coax. Some use a 64:1 xfmr. Don't forget to use a 1:1 to help block CMC on the feedline. Install it in the feed line at the outside entrance to the shack. You can buy a 4x4x2 wx proof electrical junction box at Lowes or Home Depot (or online) for using a FT240 size core. It works great. You can also build your 1:1 on a FT240-43 and use a electrical junction box for it.
    Another good place for a kit or kit parts is HF KITS which is in Europe. They have good stuff but the exchange rate in currency and shipping means it gets a little expensive. Still there on line instructions for their kits may help someone.
    73 and keep up the good work!
    Experimenting with antenna design is a great part of being a Ham! I love it!
    N3TGY, KS0E, K9EI and 1 other person like this.
  14. NJ3T
    Where did you find a FT240-52 core and the wire for a 64:1 for $10 ? I am interested in buying some.
    K9EI likes this.
  15. K9EI
    They were much less than $10. My entire sha-bang was $10. Smaller size 1.5" cores. Ham-fests are your friend......
