ad: MyersEng-1
The uncomfortable truth about how ham radio manufacturers specify their products
Discussion in 'Videos and Podcasts' started by 2E0HTG, Jan 31, 2022.
  1. 2E0HTG
    2E0HTG Ham Member QRZ Page
    Check this out:
    73s,
    Clint M0OXF
  2. KC7JNJ
    KC7JNJ Ham Member QRZ Page
    Is everything grounded including your MFJ?
  3. WG7X
    WG7X Platinum Subscriber Platinum Subscriber QRZ Page
    Hi Clint, good afternoon!
    Based om my somewhat limited usage of the MFJ tuners, I will have to say that the MFJ product is by far the weak link there. That said, I too have a "300 watt" MFJ tuner and I've been able to arc it using only 100 watts. It really depends on frequency as you've already found, and the mismatch that the tuner is being asked to tune. 160 Meters ( aka Top Band) is usually harder to match than other bands. I have a couple of kilowatt plus (supposedly) tuners that cannot match high power on 160 without some drama, or no match at all.
    I'm currently using a full wave 80 meter loop. My Palstar AT-4K will match it, barely and the Nye-Viking won't find a match at all on 160. Both of those tuners are well made, with big high-voltage and current capacitors and inductors.
    So, I guess what I am saying is that whet you are seeing is, sadly, about what you can expect from a piece of equipment like the MFJ tuner. It's not that the tuner can't load an antenna, it's just, as you point out, that the specifications for the tuner might be a bit optimistic. To say the least!
    KC7JNJ likes this.
  4. 2E0HTG
    Hi yes it is. 73
  5. 2E0HTG
    Thanks for your comments - I agree with you in regard to the MFJ almost certainly being the weak link here - and you're quite right that top band is harder to match. 73
  6. K7TRF
    Antenna tuner power ratings are poorly defined and subject to a lot of interpretation. Here's a section from the Ameritron ATR-30 tuner manual that speaks to just that:
    Different manufacturers handle this in different ways but it's not unusual to see tuners arc over well below their advertised power ratings especially on 160m.
ad: Schulman-1
