My Log4OM seems to be logging to QRZ, but JTAlert logs are not. Edit, looking at other things, it might be JTAlert with the issue.
Edits to log entries not being saved? I manually entered several QSOs. No problems with the entries being accepted. However, I noticed on one entry that I made an error in the RST fields. I selected the call that I wanted to edit. Selected edit. I then corrected each RST field to change the report of sent and receive. I changed the sent from "59" to "55" and the receive from "59" to "57" and then selected SAVE. Left the QRZ logbook. Came back to the home page several minutes later to read comments and noted others were saying that edits were not being saved. I checked the call that I edited the RST fields and each field had returned to "59" and did not save the changed entries of "55"/"57"
I see you are making progress. However as of now 11:11 pm Eastern time.....cannot download to lotw, cannot correct data recorded in error, such as time of qso and cannot download to eqsl. Good luck with fixing current bugs. Thanks for your efforts.
Just checked a few minutes ago (see time) and Mark 9L1YXJ , who is overseas, working in Sierra Leone for a bit, was my only contact...a few days ago, right before the ReFit YMMV Well Done Guys & Gals @ QRZed. And guess what?? I SURVIVED! Best 73/88 to all, and all a good evening. Mr. Carl de NĂ˜CEL
Fantastic. And thank you for the quick reply to my help desk enquiry, during what would have been a very busy and trying time. Cheers.
Can't edit any QSO record. It pretends to save the change but reverts back to original. In other words, changing the frequency, band, ETC no workie. These are LOTW imported records, and am not sure if that matters or not. Growing pains. Par for course. It will all work out eventually!
I am finding incorrect time showing up in the logbook and I am unable to edit it to correct time. I input my QSO with KE0KET as 20:31 and it stays at 22:31. This is not the only time acting like this on manual input. If I import then it looks fine.
