ad: cq2k-1
First 10 Days with a New Flex-6400
Discussion in 'Amateur Radio News' started by N6OIX, Sep 10, 2019.
Tags:
  1. WX4W
    WX4W Ham Member QRZ Page
    I have a Kenwood TS-990 as my main shack rig and recently added a Flex 6400 and a Maestro to the Shack. I agree with most here that the 6400 is a fine rig but it's not all roses. When using the Maestro on my neighbor's deck there is a fairly significant latency or delay that you need to get used to when running remote. Both my neighbor and I have very fast internet but the delay is noticeable. Now I must add that when working locally on my LAN the delay isn't an issue and the Flex makes operating remotely very easy.
    I've also seen a delay when using CW and a local set of paddles connected directly to the Flex. This week I've setup my laptop to operate remotely and configured N1MM to control the Flex and plan to play in the CWT next week while on vacation in Florida. It will be interesting to see how the delay impacts operating in that.
    As far as the comments from people saying they thought they'd miss the knobs and buttons of a traditional radio but found that they do not...my experience is different. I much prefer my 990 over the Flex when operating at my station desk. For me a traditional radio is faster to operate and easier to tune than using a mouse. The Maestro would be a must for me if the Flex was to be my main radio. But the 6400 has capabilities that make it for me a great second or backup radio..... such as allowing remote operation from my deck, upstairs or another state away. For me the Flex is the best choice as a backup radio because of the added capabilities while still being a great rig to use as my main radio if the 990 has to go in for repair. The Flex really compliments a traditional radio setup fantastically.
    Again this is just my opinion to offer another view from a happy Flex user and I am in no way throwing shade on the Flex. The Flex is a fantastic radio but my point is that every radio has both pros and cons. As they say, your mileage may vary,
    KR3DX and K2XT like this.
  2. VE3TMT
    VE3TMT Ham Member QRZ Page
    I believe QRZ used the term "review"
    Very nice setup. I'm curious how you lit up the mic?
    Makes me want to ditch my small monitors. I have a 40" flat screen sitting in a box unused, that may be put into use soon ;)
    KN6ECE likes this.
  3. W4DSD
    W4DSD Ham Member QRZ Page
    I don't know about the rest of you, but I enjoyed reading about his new radio and how he was using its features much more than the "News" articles. Good job and continue using that awesome setup.
    N5NOQ, W1TRY and KN6ECE like this.
  4. AJ2I
    AJ2I XML Subscriber QRZ Page
    I had a 6400 but sold it and went back to superhet radios. The 6400 RX is deaf on weak signals. Look at sherwood's measurements, -112dBm on RX, the worst on the list by far. All the Flex radios are terrible at MDS and pulling in weak signals. A 706 does a better job and much more sensitive. When you can't hear a signal but every other rig can, it's a problem.
    KA2FIR and KR3DX like this.
  5. AE2B
    AE2B Ham Member QRZ Page
    looks like im standing in best buy
  6. KA0HCP
    Well no, that's not the whole story. With the preamp on the Flex 6400 (-136 dB) is within 2 dB of the Elecraft K3 (-138 dB) on CW MDS/Noise Floor, (first column). Adjust the controls to fit the operating goal.
    Note: Of course, on HF bands, the atmospheric Band noise is typically the limiting detection factor for most stations (not to mention man made ambient noise). Excess sensitivity becomes useless and nothing more than a bragging point.
    KC7CS and N6OIX like this.
  7. VE3TCV
    VE3TCV XML Subscriber QRZ Page
    One thing to add is the preamp on the Flex 6600 is beyond anything I have used in the past, when there is a weak signal I simply crank it up to +32dB and the signal blasts through while the noise stays the same! Using receive specific antennas are a joy with a preamp of this class.
    N6OIX likes this.
  8. KR3DX
    KR3DX Ham Member QRZ Page
    Yours is not the whole story either. Turning on the preamp significantly degrades the dynamic range on an SDR, much more so than on a superhet. On Rob Sherwood's website, look at the dynamic range specs for the preamp on and the preamp off. Another limitation of a direct sampling SDR is that the FPGA has a maximum voltage limit that is affected by THE SUM VOLTAGE OF ALL OF THE SIGNALS WITHIN ITS PASSBAND, which add to its noise floor. The 6400 does not have band pass filters, so ALL of the signals on the ham band (think contest weekend) and ALL of the signals adjacent to the ham band (SW broadcast, etc.) are present on the input of the FPGA, severely limiting its ability to "hear" any individual signal. The ARRL and Rob Sherwood use a "two tone test" to determine dynamic range, which is a valid method for a superhet, but it falls far short of revealing the weakness of an SDR. With a superhet, you can have sensitivity AND dynamic range, with an SDR you must choose sensitivity OR dynamic range, which are both WORSE on the SDR. In the "real world", SDRs perform FAR worse than the "specs" seem to indicate. Look at the "100 kHz Blocking" figures on Sherwood's website. This is why the best receivers are superhets, and according to Kenwood, it's why they designed the TS890 as a superhet instead of an SDR.
    Yes, "band noise" is the limiting factor on the lower HF bands, but unless you NEVER operate above 20M, you will probably want a rig with decent sensitivity. 73
    KA2FIR, AJ2I and KA0HCP like this.
  9. KA0HCP
    You can always add bandpass filters to the Flex radios. You can't add flex equivalent displays to any non-flex radios. :)
    Every radio has it's operating limitations and quirks. No radio does everything all the time in every mode.
    N6OIX likes this.
  10. KR3DX
    Adding band pass filters still does not negate the limitations of an SDR. Like the ham band filters on the Flex 6600 and 6700 series (which are MUCH more expensive than the 6400 series), they do NOT eliminate the in-band (ham) signals. Think contest, QSO party, special event, or any other scenario where the band is full of signals. It's a BIG disadvantage for the SDR vs. the superhet. Again, look at the "100 kHz blocking" specs on Sherwood's site, but even that doesn't tell the whole story. Regarding displays (eye candy), many other rigs have "pan-adapters" or external video display ports which have even more Flex-ability (pardon the pun) than the Flex. You could use an SDRplay RSP-2 receiver (< $200) for a wideband spectrum display by connecting it to a separate antenna, and connect the second input of the SDRplay to the IF output of your rig to display the rig's passband. That setup would also be more flexible than the Flex. I do agree with you that no rig is perfect.
    KA2FIR and AJ2I like this.
  11. KA0HCP
    BTW, The Marconi Italian Navy Coherer receiver has better EMP resistance than all modern radios. Therefore, all current production radios are terrible designs. :)
    The danger of the Sherwood numbers (as demonstrated in this thread) is that they can be cherry picked to highlight a particular radio and bash others claiming absolute superiority in a single number without context.
    The Flex 6400 radio is not a terrible radio. The Kenwood TS-890 is not the 'best" radio.
    The Flex 6400 isn't the best radio for CW contesting under battle conditions, or absolute weak signal CW work. So what. Pick a top of the line Yaesu and criticize the four deep menus or poor ergonomics or cheap knobs. Whatever. Comparing the Flex to the DISCONTINUED IC-706 is an exercise in pointlessness.
    Many excellent points have been brought up in the discussion. I think that contributors should back down on making absolute claims of superiority or inferiority. Lighten up bit. bill.
  12. KA0HCP
    On the contrary. External bandpass filters (available off the shelf as plug and play e.g. from Array Solutions) DO eliminate the other 90% of the HF spectrum impinging on the Flex receiver, thereby improving the Dynamic Range performance on the desired band, which negates previous criticism.
    Point 2; Don't think contest battle conditions.
    Point 3: Non-graphic radios still can't compete with the primary graphic display and controls of the Flex's. Kluging low end RTL's, drilling and blasting and modifying expensive radios is not a hearts desire of most hams. Further most radios don't have IQ/IF outputs for plug and play. Additionally, you ares still left operating now two (2) radios in order to get the visual display that are the Flex forte.
    Thrust, parry, riposte! Touche'
    Bottom line: We have outstanding radios available to us today at all time low relative cost. Even the entry level radios today have excellent performance and features compared to a few decades ago! b.
  13. AJ2I
    Preamp adds noise. Most of the Non Flex radios made within the past 20 years have MDS numbers around -125+. Going +32 on a flex to equal a non-flex radio adds a TON of noise , almost to the point where you won't be able to hear the signal.
    I had a Ten Tec Eagle, and my 6400, side by side, A/B switch. Same antenna and everything. The Eagle heard the weak signal, the 6400 didn't. Hams need to A/B radios side by side to see the real world difference. The best way to decide for yourself.
    KA2FIR, AF6IF, K2NCC and 3 others like this.
  14. KR3DX
    I agree 100%
    AJ2I likes this.
  15. KR3DX
    I inserted my comments in bold after several of your statements in your reply above.
    KA0HCP likes this.
ad: QSLWorks-1
