Are antennas altered in the presence of carbon fiber masts?
Discussion in 'Amateur Radio News' started by KX4O, Mar 13, 2021.
  1. KX4O
    KX4O XML Subscriber QRZ Page
    The N9TAX antenna used in the test has a reasonably effective choke at the feed point that I've verified suppresses common mode tendencies by about 10 dB. I guess I could add another one 1/4 wave down for the coup de grâce, but that will have to wait for another time.
    WF7T likes this.
  2. KX4O
  3. K6CLS
    K6CLS Ham Member QRZ Page
    some resins use metallic adjuncts (JB Weld) and are slightly conductive.
    AK5B and KX4O like this.
  4. N7EKU
    N7EKU Ham Member QRZ Page
    Everything is slightly conductive!
    According to the manufacturer though, it is not:
    https://www.jbweld.com/faqs
    But I've never measured it myself. Have you?
    73.
  5. AC1CP
    AC1CP XML Subscriber QRZ Page
    Again not an expert on materials or chemistry. To me the clay acts like a binder and to hold it's shape. Have you seen where they use graphite a form of carbon from a pencil and play around with making a resistor on paper?
  6. AC1CP
    one guy mentions "However, carbon fibers are also composited with other materials, such as with graphite to form carbon-carbon composites, which have a very high heat tolerance." from https://www.researchgate.net/post/Is-carbon-fiber-and-graphite-fiber-means-the-same
    This is just what I find on the web as I have no expertise in the subject matter.
  7. AK5B
    AK5B XML Subscriber QRZ Page
    JB Weld comes in a number of different "flavors." I use a lot of their KwikSteel in my lapidary work and I believe it has powdered steel suspended in it---so it must be at least somewhat conductive. The basic JB Weld 2-part epoxy is likely what the company was referring to unless I am mistaken.
    K6CLS likes this.
  8. K6CLS
    yes I have run DC and RF tests on a variety of materials, layups, etc. About 15 years ago we were trying to get GPS reception (and APRS transmitter) to work in a high power model rocket. Best place to mount the tracking stuff is in the nose cone. But we found that the GPS reception was unreliable in a certain manufacturer's carbon fiber nose cones. So we ran a bunch of tests. Turned out to be a whole bunch of factors, not just RF attenuation..
    The DC conductivity of the carbon fiber airframe parts was an issue for mounting control circuitry, switches, etc. Easily solved with careful mounting and cardstock insulation.
    And, yes the (high temperature) JBWeld was conductive enough to interfere with the motor initiator, leads accidentally touched the epoxy used for the motor mount, oops. We also experimented with high temp ceramic epoxy (very $$$$ aerospace stuff!), turned out to be too brittle and didn't wet out the fabric.
    Sorry I do not have the report handy. But yeah, this emphasizes my point that there are quite a few variations in the materials, and some times it matters.
    (In the end we went with a conventional fiberglass nose cone, good enough is good enough! If it doesn't survive a few Mach 3+ flights, then just call it a consumable and get another one.)
    N7EKU and KX4O like this.
  9. MW1CFN
    MW1CFN Ham Member QRZ Page
    Interesting. But it needs tidying up. The massive dip with the wood stick is dismissed as unimportant, largely because we don't expect it to have this impact. It seems to have been down to bad body/hand positioning. So until all the materials are introduced without a human body affecting the results, we can't be entirely satisfied with the result.
    AK5CT likes this.
  10. N1IPU
    N1IPU Ham Member QRZ Page
    I have to guess some tower manufacturer is looking at carbon fiber. Whole new can of worms regardless considering UV and grounding. Still prepeg tubes are easy to work with and stronger by far. Most what would be needed is off the shelf these days.
  11. HB9EPC
    HB9EPC Ham Member QRZ Page
    [QUOTE = "WB6MPH, post: 5796547, membre: 837383"] J'ai une petite expérience avec la fibre de carbone et les panneaux solaires. J'ai travaillé sur une voiture de course solaire en 1987. L'un des nombreux panneaux solaires flexibles n'était pas correctement isolé à l'arrière. Après avoir été collé et au soleil, quelqu'un a remarqué que le panneau était en court-circuit. Nous avons trouvé des fibres de carbone qui traînaient et les avons mises sous tension. Ils brillaient en rouge comme un radiateur infrarouge, alors oui, ils sont très conducteurs, bien qu'ils aient plus de résistance qu'un fil de cuivre. Je m'attendrais à une certaine absorption des RF, ce qui modifierait la capacité-réactance par rapport à un pôle en fibre de verre. [/ QUOTE]
    Voilà un test pratique plus efficace que du Blabla...
    Chris.
  12. PA0MHS
    PA0MHS Ham Member QRZ Page
    A carbon fiber mast would indeed require a UV resistant coating of paint, preferably in a light color (white) for best UV resistance. As for lighting: a direct hit will make the mast explode.
    KX4O likes this.
  13. VE3VXO
    VE3VXO Guest
    That would be OK as long as the guitar had plastic strings otherwise the RF burns would be ruination for your calouses. Oh wait, never mind the deer's hooves wouldn't feel it.
  14. KX4O
    Any non (or very low) conductive materials with a dielectric constant greater than one should be easily noticed with an S11 test like this... hence not surprised to see an effect. That said, I did expect the dip to move down in frequency as is the case with insulated wire and antennas placed inside a PVC pipe. It didn't, but went with the data as shown.
    Yeah... the hand. Should have held it at the bottom to remove that variable. This was my forth take with three cameras and was getting anxious to finish. Next time. At least the antler test with hand gives some hand to hand comparison.
    Fair enough. The other two references introduced in the video make the question of CFC conductivity rhetorical, but I hope this demonstration inspires others to confirm it for themselves.
  15. N1IPU
    Properly bonded I don't think it will explode. Aircraft composites use many method but usually a copper mesh in the outer layers.
ad: MLSons-1
