Xml down?
Discussion in 'QRZ XML Logbook Data' started by KA4RON, Dec 27, 2016.
  1. KA4RON
    KA4RON Ham Member QRZ Page
    I and one other subscriber find xml lookup from HRD has stopped working this afternoon. Is there any timetable as to when the problem will be fixed? I assume QRZ knows there is a problem.
  2. AF4M
    AF4M XML Subscriber QRZ Page
    I am having the same problem. I am running HRD ver 5.24 and everthing was fine yesterday but nada today.. anyone else having problems or know the cause???
  3. KC2MBV
    KC2MBV Premium Subscriber QRZ Page
    I haven't been able to preform lookups all day also.
  4. IZ4REF
    IZ4REF Premium Subscriber QRZ Page
    I' ve also the same problem from Yesterday, my account expire in 2017/12/25:(
    IZ4REF Riccardo
  5. WN9W
    WN9W Guest
    Also seeing problem. Running HRD v5.24.0.36. I see the following when testing the interface from within HRD:
    <head>
    <Lookup Options="2">WN9W</Lookup>
    <Callsign></Callsign>
    <Source>QRZ.com subscription interface</Source>
    <Status>Username / password required</Status>
    <Valid>No</Valid>
    <Timestamp>2016-12-28 10:03:16</Timestamp>
    </head>
    I can log in at QRZ.com without a problem.
  6. KA9JLM
    I would guess that may be the problem.
    The variable must be missing for some reason.
  7. YO6OHD
    YO6OHD Ham Member QRZ Page
    Not working for me also in HRD, working only in qrz.com browser since today morning...
  8. EB5AH
    EB5AH XML Subscriber QRZ Page
    In another software if it works, but does not give access to HRD.
    Same problem HRD V5.24.0.38
  9. AI8F
    AI8F Ham Member QRZ Page
    Same here. Started yesterday and still not getting data.. Also using HRD 5.2 Anybody got a remedy?
  10. WQ9F
    WQ9F XML Subscriber QRZ Page
    Using HRD 5.24 also and have not been able to perform lookups as well. I was beginning to wonder if something was wrong with my end but looks like i'm not the only one having issues.
  11. KA9JLM
    Maybe the server address was changed again.
  12. AA7BQ
    AA7BQ QRZ Founder QRZ HQ Staff QRZ Page
    Thanks for your reports. This issue apparently affects only the older 5.x versions of HRD. We're actively looking for the problem which appears to be with the authentication mechanism. We should have a fix shortly. -fred
    KA4RON, KA9JLM and G1WEV like this.
  13. AI8F
    Thank You
  14. K3LU
    K3LU XML Subscriber QRZ Page
    Im having the same issue with N3FJP's Amateur Contact Log
  15. AA7BQ
    Good morning folks,
    Happy to report that we found the source of the issue and have corrected it. The problem was that the older software doesn't go directly to the XML server for lookups. The older programs go to www.qrz.com whereas the service actually exists at xml.qrz.com. The "redirect" message that our www server was sending out wasn't being interpreted by the old HRD because it does not know how to handle HTTPS (secure) connections.
    This morning I installed special code (again) to address the issue and the fix was verified by using an actual copy of the old HRD software. This issue is now closed.
    -fred
    P.S. Nobody should expect a given software program to run forever. The rest of the online world is constantly evolving and unless software evolves with it, it gets left behind. Those who are using software that is more than a few years old should consider getting an update. This goes both for older versions of Windows (anything before Win 7) as well as the programs you run. These things cannot be supported in perpetuity and will eventually fail due to their age and non compliance with current standards.
ad: RaySult-1
