SB DX @ WW < KB8NW $OPDX.1309 Ohio/Penn DX Bulletin No. 1309 The Ohio/Penn DX PacketCluster DX Bulletin No. 1309 BID: $OPDX.1308 March 20, 2017 Editor Tedd Mirgliotta, KB8NW Provided by BARF80.ORG (Cleveland, Ohio) Written/Sent from Strongsville, OH Thanks to the Northern Ohio Amateur Radio Society, Northern Ohio DX Association, Ohio/Penn PacketCluster Network, AB5K & the AR TelNet Clusters Network, NJ1Q & W1AW, NG3K & ADXO, W3UR & The Daily DX, N4AA & QRZ DX, K8GI, K8YSE, W8GEX & 60m DX News, ND9M, CO8ZZ, DL1SBF, DL7UXG & The DX News Letter, DxCoffee.com, DXNews.com, DX-World.Net, ES1CW, F6AJA & Les Nouvelles DX, I1JQJ/IK1ADH & 425 DX News, I2MQP & DX Italia News, IK0EFR, OZ6OM & 50 MHz DX News, PA3CNO, RSGB IOTA Web Site, Sixitalia Weekly, VA3RJ & ICPO, and VHF-DX-Portal (MMMonVHF) for the following DX information. DXCC COUNTRY/ENTITY REPORT: According to the AR-Cluster Network for the week of Sunday, 12th/March, through Sunday, 19th/March there were 233 countries active. Countries available: 3A, 3B8, 3B9, 3D2, 3DA, 3V, 3W, 3X, 4J, 4L, 4O, 4S, 4X, 5A, 5B, 5H, 5N, 5R, 5T, 5U, 5V, 5X, 5Z, 6W, 6Y, 7X, 8P, 8R, 9A, 9G, 9H, 9J, 9K, 9M2, 9M6, 9N, 9Q, 9V, 9X, 9Y, A2, A3, A4, A6, A7, A9, AP, BV, BY, C3, C5, C6, C9, CE, CE0Y, CE9, CM, CN, CP, CT, CT3, CU, CX, D2, D4, DL, DU, E5/n, E5/s, E6, E7, EA, EA6, EA8, EA9, EI, EK, EL, EP, ER, ES, ET, EU, EX, EY, F, FG, FK, FM, FO, FR, FS, FY, G, GD, GI, GJ, GM, GU, GW, H4, H40, HA, HB, HB0, HC, HH, HI, HK, HK0/a, HL, HP, HR, HS, HZ, I, IS, J2, J3, J5, J6, J7, J8, JA, JD/m, JD/o, JT, JW, JY, K, KG4, KH0, KH2, KH6, KH8, KL, KP2, KP4, LA, LU, LX, LY, LZ, OA, OD, OE, OH, OH0, OK, OM, ON, OX, OY, OZ, P2, P4, PA, PJ2, PJ4, PJ5, PJ7, PY, PZ, S0, S2, S5, SM, SP, ST, SU, SV, SV5, SV9, T2, T30, T32, T7, T8, TA, TF, TG, TI, TK, TL, TR, TU, TY, TZ, UA, UA2, UA9, UK, UN, UR, V2, V3, V4, V5, V7, V8, VE, VK, VK9X, VP5, VP8, VP8/h, VP9, VR, VU, XE, XT, XU, XX9, YA, YB, YI, YL, YN, YO, YS, YU, YV, Z2, Z3, ZA, ZB, ZD7, ZD8, ZF, ZL, ZP, ZS, ZS8 * PLEASE NOTE: The report "could" contain "Pirate/SLIM" operations or more likely a "BUSTED CALLSIGN". As always, you never know - "Work First Worry Later". 8P, BARBADOS. Tom, W2SC, will be active as 8P5A during the CQWW WPX SSB Contest (March 25-26th) as Single-Op/All-Band/High-Power entry. QSL via LoTW or direct to NN1N. A2, BOTSWANA (Update). A UK Team will be active as A25UK from Botswana between April 25th and May 6th. Operators mentioned are Nobby/G0VJG, Dave/ G4BUO, Nick/G4FAL, Graham/G4FNL, Tony/G4LDL, YL Glenys/G8KWD, Guy/G0UKN, Martin/M0MDR, Toby/M0TBS and Giles/M0TGV. Activity will be on 160-6 meters using CW, SSB, RTTY and PSK. Suggested frequencies are available as a PDF file per the following languages (EN/IT/ES/FR/DE/JA/RU) at: http://www.a25uk.com/2017-2#mhz QSL via M0OXO or via ClubLog's OQRS. Also, visit their new Web page at: http://www.a25uk.com AH2/KH2, GUAM. Operators Santos/EA4AK (AH2P) and Tony/EA5BY (KH2BY) will be active from Guam between March 30th and April 10th. Activity will be on 160-10 meters, but a focus on the lower bands (160/80/60/40/30m) using RTTY and CW, with some SSB. Look for AH2P to operate mostly on RTTY and KH2BY mainly on CW. Reports indicate that they will be on higher bands, but mostly for western Europe. QSL AH2P is preferred via LoTW, eQSL or ClubLog's OQRS. Later all AH2P QSLs will be sent by the Bureau. Please, no direct or Bureau QSLing to AH2P to Guam's QTH. Send all your QSLs, direct or via the Bureau, to EA4AK. QSL KH2BY only via EA5BY (see QRZ.com address), by the Bureau, ClubLog's OQRS, GDURE and LoTW is OK. Do not send direct QSL to the KH2BY QTH listed on QRZ.com, please. DXCC NEWS. The ARRL DXCC Desk has approved the 2016 November operation by E44CM from Palestine for DXCC credit. E5, SOUTH COOK ISLANDS (Update). Milan, OK1DWC, who is still active as E51DWC from the Rarotonga Islands (OC-013, WAZ-32), will be there at least until sometime until the end of March. Milan is active every day on 160-10 meters using CW, SSB and RTTY. Look for him to be in the CQWW WPX DX SSB Contest (March 25-26th) as a Single-Op/All-Band/High-Power entry. QSL via his home callsign. Confirmation is not a problem across all OQRS's and the information can be found on: http://QRZ.com/lookup/E51DWC http://QRZ.COM/lookup/OK1DWC http://www.hamqth.com/E51DWC E5, SOUTH COOK ISLANDS. Operators Bruce/AD7MM (E51BAS) and Doug/W6HB (E51DLD) will be active from Rarotonga Island (OC-013) between April 30th and May 12th. Activity will be holiday style on 160-10 meters, and operating from E51AND and E51KC QTHs (also possibly from E51JD, E51BQ and E51CG QTHs). QSL via their home callsigns direct (sse QRZ.com). ED8, CANARY ISLANDS. Operators Alvaro/EA8JR, Jorge/EA8TL and Manuel/EA8DO will be active as ED8W from La Palma Island (AF-004) during the CQWW WPX SSB Contest (March 25-26th) Multi-Op entry. QSL via EA8DO or LoTW. HB0, LIECHTENSTEIN. A group of Dutch radio amateurs (from the PI4RAZ Radio Club) will be active as HB0/homecall from Liechtenstein between April 1-8th. Operators are Mans/PA2HGJ, Robert/PA2RDK, Frank/PA3CNO, Paul/PA3DFR, Henry/ PA3HK, Gert/PE0MGB and Piet/PE1FLO. Operations will be on all bands, 160-10 meters, using mainly CW and some SSB/Digital modes with an emphasis on the new 60m band. QSL via PE1FLO. HH8, HAITI. Doug, KD8CAO, will once again be active as HH8/KD8CAO from Jacmel, Haiti (FK38rf), on both satellite and the HF bands between March 19-23rd. The primary purpose of Doug's travel to Haiti is missions work (he and his team will be installing a solar array to power Radio Lumiere's FM broadcast station in Jacmel); amateur radio is secondary, so don't expect him to be active on every pass. He plans to operate both SSB and FM satellite as time allows, HF operation is planned for 17m and/or 20m SSB, typically evenings between 2000-0000z. For those needing Haiti as a new DXCC on satellite, please send Doug an E-mail at <kd8cao@amsat.org> or via private Twitter message to indicate your interest in a sked. Activity updates will be posted via Twitter, follow @KD8CAO. QSL via direct w/SASE and/or LoTW (upload upon return to USA). IOTA NEWS.............. AF-064. Operators Ashley/ZS1ASH, Grant/ZS1GS, Mari/ZS1MW and Elizabeth/ ZS1XS are now active as ZS1FUN from Dassen Island until March 22nd. Activity has been on 40/20 meters using mainly SSB. QSL via the Bureau or requests via E-mail at: info[at]zs1fun.co.za zs1fun.sa[at]gmail.com AS-071. Members of Russian Robinson Club (RRC) will be active as R71RRC from the Arakamchechen Island (RRA RR-12-02, RDA CК-06, RFF-165 [NEW ONE], RLHA [NEW ONE], WLOTA [NEW ONE]), near the Chukotka Peninsula, in the Bering Sea Coast North Group, Asiatic Russia, between April 7-17th. The dates are tentative and dependent on local logistics and weather conditions. Operators mentioned are Aleksandr/RA3AV, Yuri/UA0KBG and Victor/UA3AKO. The team plans to be on the island at least 5-7 days. They plan to have two operating positions on the air on 40/30/20/17 meters using CW and SSB. Equipment to be used: two Elecraft K3's, FT-857 (for backup), two 500 watts power amplifiers. The antennas are: 4 SQ for 20m, GP or 2 elements switchable for 30m, GP for 17m and GP for 40m. The electricity to be taken from two power generators (main and backup). QSL via UA3AKO, ClubLog's OQRS, direct and QSL Bureau. DXpedition's Web site in now online at: http://r71rrc.ru/en/ EU-121. Fred, ON6QR, will be active as EI/ON6QR from Tory Island during the RSGB IOTA Contest (July 29-30th) as a Single-Op/CW-Mode entry. QSL via his home callsign. OC-098. Cezar, VE3LYC, has announced that he will be active as E51LYC from Pukapuka Atoll (Danger Islands), North Cooks Island, between May 9-23rd. This IOTA group has not been activated for more than 22 years. More details will be forthcoming and a Web site is currently under construction. IQ0, ITALY (ARI 90 Years Award). Look for special event station IQ0PG (Sezione A.R.I. Perugia) to be active between April 1-30th. Activity will be on 160-2 meters. Operations are valid for the ARI 90 Years Award. QSL via the Bureau, direct, LoTW, eQSL.cc or Clublog's OQRS. For details and rules about the U9ØARI1 special award, see: http://www.ari.it/index.php?option=...ars-award&catid=242:awards&Itemid=262&lang=it J3, GRENADA. Franz, OE2SNL, is now active as J3/OE2SNL from Grenada (NA-024) until March 30th. Activity will be on 160-10 meters using a Kenwood TS-480HX into a G5RV antenna and 160m inverted L. QSL via his home callsign. For more details, see: https://www.oe2snl.at/j3-grenada-2017 J6, ST. LUCIA. Bill, K9HZ, will once again be active as J68HZ from his villa at Labrelotte Bay, Castries, St. Lucia (NA-108, WLOTA L-1336) between April 1-8th. Activity is usually on 160-6 meters using CW, SSB and RTTY. He states, "Will try to fill some band-mode slots for WAS and DXCC. Particularly looking for AK and MT in the USA to complete 8BWAS." His equipment will consist of an Elecraft K3, a 3 element beam for 20-6 meters and wire antennas for 160-30 meters. QSL via his home callsign. He does use the LoTW, ClubLog and eQSL. J8, ST. VINCENT. Brian, GW4DVB, will once again be active as J88PI from Palm Island (aka Prune Island, WW Loc. FK92HO, IOTA NA-025), in the St. Vincent and the Grenadines Island group, between April 12-23rd. Activity will be on 40/20/17/15/10/6 meters SSB only using an Elecraft KX3 and KXPA100 Power Amp (100w) into a 10m vertical antenna and a M0CVO HW-40HP off center fed dipole. QSL via GW4DVB, by the Bureau or direct to: PO Box 20:20, Llanharan, Pontyclun, Wales - UK CF72 9ZA. For more details and updates, check: http://www.g4dvb.co.uk ADDED NOTE: Palm Island is an exclusive, private-island resort. This idyllic tropical hideaway is situated near the southern tip of St. Vincent and the Grenadines, an idyllic archipelago of 32 tropical islands and cays known for its stunning natural beauty, clear, warm waters and turtles. OE17, AUSTRIA. Look for special event station OE17ATOM to be active from the Nuclear Power Plant (inside the reactor's hall) in Zwentendorf between April 21-22nd. Activity will be on the HF, VHF and UHF bands. Operators mentioned are Stefan/OE1SSU, Franz/OE1AOA and Gregor/OE1SGW. There will be live streaming video during the operation (see QRZ.com for details). QSL via ADL303 only. Direct QSL card requests to operator's callsign will not be answered. All logged QSOs will receive a QSL. OJ0, MARKET REEF. Operators Jean-Paul/ON2KMJ, Ronald/ON5TQ, Mike/ON6QO and Peter/ON8VP will once again be active as OJ0V from Market Reef (EU-053) between July 1-7th. Activity will be on 80-6 meters with two stations on the air using CW, SSB and the Digital modes. QSL via ON5TC, direct or by the Bureau. Log will be uploaded to ClubLog during the DXpedition if they have a connection to the internet or as soon as they return back in Belgium. PA10, THE NETHERLANDS. Operators Bert/PA1BK, Alfred/PA7AL, Laurens/PD9X and Frank/PF5T will be active as PA10A from the contest station location of PI4M during the CQWW WPX SSB Contest as a Multi-One entry. QSL via LoTW. PA150, THE NETHERLANDS. Harry, PA3ARM, will be active as PA150LIM during the CQWW WPX CW Contest (May 27-28th) as a Single-Op/All-Band/Low-Power entry. QSL via PD0MHZ. Special callsign is to celebrate 150th anniversary of the Dutch Province Limburg. PROPAGATION FORECAST/REPORT (March 20-26th)....... Mar/20th AN Mar/23rd HN Mar/25th AN Mar/21st AN Mar/24th AN Mar/26th AN Mar/22nd HN SOLAR REFERENCE KEYS/INDEXES AND GEOMAGNETIC REFERENCE ====================================================== NORMALITY GEOMAG K Values Alpha ----------------- ------ -------- ------ AN - Above Normal Quiet K=0-1 0-7 HN - High Normal Unsettled K=2 8-15 LN - Low Normal Active K=3 16-29 BN - Below Normal Minor Storm K=4 30-49 DIS - Disturbed Major Storm K=5 50-99 VRY DIS - Very Disturbed Severe Storm K=6-9 100-400 REALTIME BAND CONDITIONS WEB SITE <http://www.bandconditions.com>: The purpose of this experimental Web site is to provide 24-7-365 actual (REALTIME) band condition information to CW QRPp, QRPe and CW/SSB for Contesters interested in increasing their scores. It can also be of benefit to other Radio Amateurs to determine band conditions for Nets and casual QSO's. This information is NOT based on any software pre- dictions or any kind of satellite based readings. It is based on a new Ionospheric sounding method called "HF Ionospheric Interferometry" which operates very similarly to the PolSAR system used by NASA. Also, check out the VOACAP predication Web page at: http://www.voacap.com/prediction.html A daily HF radio wave propagation forecast can be found at: https://www.facebook.com/thomasfranklingiellaw4hm Also on Twitter: https://twitter.com/@GiellaW4hm QSL INFO AND NEWS................... QSL-INFO from DB0SDX by Lothar, DL1SBF.. (March 19th) <www.qslinfo.eu> ------------------------------------------------------------------------- 5T2AI via NI5DX HI3/N3SY via N3SY OE2017IIO via OE5IIO 6E3MAYA via XE3N or (L) II0IDR via IZ0FVD (O) OE2017MPI via OE7MPI CQ3W via CQ3W (O) II3ICZ via IQ3GA OE2017MXL via OE5MXL CT9/DL3KWF via DL3KWF II8GIRF via IK8HEQ OE2017SGU via OE3SGU CV7S via CX7SS II9IGA via IT9CKA OE2017SWG via OE6SWG DL2DSD via DL2DYL (e/d) J3/OE2SNL via OE2SNL OE2017VIE via OE4VIE DP6A via DL8OH KL7J via N3SL OE40WG via OE6XUG E2A via E21EIC & (L) KL7RST via K7ICE PJ2/DL1RNT via DL1RNT EA7/M0TTT via M0TTT (L) LY/UA4WHX via UA4WHX S21ZED via YL2GN (OQRS/L) EA9/DL7DF via DL7DF LZ5R via LZ1YQ TC102GS via TA3AHJ EA9/DL7UFN via DL7UFN M7O via M0VKY (O) TM40LUB via F4PCM EH3DWN via EA3HKY (L/e) MJ5Z via M0CFW (O/L) UP0L via DL8KAC EK/R2DX via R2DX OE2017AKD via OE6AKD UP2L via UA9AB GI5I via GI4DOH OE2017CCN via OE5CCN VE3GFM/W4 via VE3GFM HB0/DL2JRM via DL2JRM OE2017CFC via OE3CFC YL/UA4WHX via UA4WHX HB0/HB9RB via RC3C OE2017FKS via OE3FKS HF800O via SP6PAZ OE2017GTU via OE1GTU (e) eQSL only (d) direct only (B) Bureau only (*-B) DX's- Bureau (O) OQRS only (C) ClubLog only (L) LoTW only (*) No QSL Needed QSLS RECEIVED VIA LoTW: 3B8/G3TXF, 4O4A, 5Z4/DL2RMC, 9G5X, CP6CL, HH2AA, HR5/F2JD, NP2X, OJ0DX, S55SL, T31T, UT1AA and YS1YS QSLS RECEIVED VIA MAIL: A35W, 7X4AN, HB0/DK4YJ and ZC4A QSLS RECEIVED VIA THE BUREAU: 5B4ES, 5B4MF, E71EZC, E72WG, E73EPA, E74X, E75O, E76C/P, E77AO, E78G, OA4AI, OA4CN, OA4CPY, P3J, PY3ETS, PY3KV, R2015GV, T93Y, T94JS, T94VT, TO4K, VE3CFN, VE3IKT, VE3KP, VE3MCE, VE3NOO, VE3OTL, VE3QN, VE3VDX, VE7DP/7 (IOTA NA-181), VE7VAW and XL3T SI9, SWEDEN. Operators Jef/DD2CW and Dirk/ON3UN will be active as SI9AM from the "King Chulalongkorn Memorial", the largest Thai Pavilion in the world outside Thailand in Raganda, Sweden, between March 22-29th. Activity will include the CQWW WPX SSB Contest (March 25-26th) as Multi-Single entry. Suggested frequencies outside of the contest are: CW - 1817, 3517, 7017, 10117, 14017, 18077, 21017, 24897 and 28017 kHz SSB - 1840, 3760, 7060, 14210, 18160, 21310, 24960 and 28510 kHz FM - 145.550 MHz and repeater RV49 - 145.612 MHz QSL this operation via ON3UN. Visit the SI9AM Web page at: http://www.si9am.com http://www.si9am.se SILENT KEY. Members of the Northern Ohio DX Association were sadden this past week to learn their long time Vice President Dwaine Modock, K8ME (ex-WA8MEM), became a Silent Key unexpectedly late Saturday evening on March 11th, at the age of 68. Dwaine was a WAS and VUCC card checker, a member of FIST #1466, a Life Member of the ARRL, Life Member of the QCWA #22130, a Life Member of INDEXA and a member of OMISS #6316. He had DXCC Honor Roll Mixed 351, DXCC Honor Roll Phone 347, DXCC Honor Roll CW 344 and DXCC on RTTY 289. Dwaine had many friends and belonged to many associations and clubs. He will dearly be missed by all. OPDX and readers would like to send out our deepest sympathy to the family and friends of K8ME. T2, TUVALU (Reminder). Operators Jacek/SP5EAQ and Marek/SP7DQR are now active as T2AQ and T2QR, respectively, from Tuvalu between March 14th and April 6th. Activity will be on 80-10 meters. Jacek will operate only SSB, while Marek will operate the Digital modes (mainly RTTY) and CW. QSL both callsigns via SP7DQR, direct, by the Bureau or LoTW (after the operation). Online logs with an OQRS for the Tuvalu activities will be available on SP7DQR's Web page during the operation at: http://sp7dqr.pl/en/oqrs.php Logs will also be on ClubLog after the operation. For more details and updates, see: http://tuvalu.sp7dqr.pl/index.html T32, EASTERN KIRIBATI ISLANDS. Ken, KH6QJ, will once again be active as T32AZ from Kiritimati Island (OC-024) between April 11-18th. Activity will be on 80/40/20/15/10 meters using SSB. He will also be in the WAPC Contest (Worked All Provinces China) [See: <http://www.mulandxc.org/438>] QSL via his home callsign, direct or by the Bureau. T40, CUBA. Raul, CO8ZZ, informs OPDX that several operators from the Las Tunas Contest Crew (T48K) [including CO8ZZ] will be active as T40A during both the CQWW WPX SSB and CW Contest (March 25-26th and May 27-28th) as a Multi-Single/Low-Power entry. The main goal of the operations will be to introduce new contest operators to their local contest station (Las Tunas Contest Crew T48K) and the development of contesting skills on them. Operators list also include CO8TH, CM8ADT and CL8RCT. T8 PALAU. Kiyoshi, JA0EKI, is once again active as T88XH from the VIP Guest Hotel (Free Radio Room) on Koror Island (OC-009) until March 22nd. Activity will be on 160-10 meters using CW, SSB and the Digital modes. QSL via JA0EKI. For more details about the VIP Guest Hotel (Free Radio Room), see: http://www.palau-radio.com/index.php?page=rr2014 T8 PALAU (Update). Operators Toshio/JM1LRA (T88TA), Kazuhiro/JA7WFT (T88FT), Shinichi/JI6IHG (T88IH) and Ichiro/JH7IPR (T88UW) will be active from the VIP Guest Hotel (Free Radio Room) on Koror Island (OC-009), between April 14-21st. Activity will be on 160-6 meters using CW, SSB, JT65 and JT9. QSL T88IH via JI6IHG. QSL T88FT via JA7WFT. QSL T88TA via JM1LRA. QSL T88UW via JH7IPR, direct, by the Bureau, eQSL, LoTW or ClubLog. For more details about the VIP Guest Hotel (Free Radio Room), see: http://www.palau-radio.com/index.php?page=rr2014 VQ917, CHAGOS ISLANDS. Jim, ND9M (VQ96JC), from Diego Garcia Island (AF-006) informs OPDX on March 14th, "Well, the local licensing office came through for me again. The VQ917JC license I asked for just came through here this afternoon." So start looking for Jim to be on the air signing as VQ917JC. Jim told OPDX he will not make an effort on 60m at this time. His operating hours are still limited to 1200-1600z max which doesn't do much good for the NA/SA ops. He states that he will probably focus on 30, 20, and 17 meters just to get VQ9 into some logs. Jim also mentioned he did bring his satellite equipment. QSL via his home call- sign. Look for more details to be forthcoming. XO1, CANADA. Members of the Canam Contest Club will be active as XO1X from Whitehorse, Yukon, throughout the year of 2017, celebrating Canada's 150th anniversary/birthday. Next big operation will take place between March 25-27th during the CQWW WPX SSB Contest (as well as the CW WPX). Operators mentioned are Gerry/VE1RM, Cary/VE4EA and Gene/KB7Q. QSL via KC1CWF. XW, LAOS. Bruce, 3W3B (HS0ZCY/XU7ADF/XW1B/AA4XR), who lives in Da Nang, will once again be active as XW4XR from Vientiane between April 12-26th, 2017. Activity will be on 80-10 meters using CW, RTTY and JT65. QSL via E21EIC and LoTW. Z6, KOSOVO. The Kosovo Amateur Radio Association (SHRAK) will be active as Z60A during the the coming CQWW WPX SSB Contest (March 25-26th). Pekka, OH2YY, will operate this station as a Single-Op/All-Band/High-Power entry. QSL via Z60A. -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- TO BE ADDED TO THE OPDX MAILING LIST -- Click or send requests to: Help: <mailtopdx-request@barf80.org?subject=help> Subscribe: <mailtopdx-request@barf80.org?subject=subscribe> Unsubscribe: <mailtopdx-request@barf80.org?subject=unsubscribe> OPDX WORLD-WIDE WEB HOME PAGE (provided by John, K8YSE): http://www.papays.com/opdx.html ALSO VISIT THE NORTHERN OHIO DX ASSOCIATION'S WEB PAGES AT: http://www.nodxa.org/ http://www.facebook.com/NorthernOhioDxAssociation -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- * All excerpts and distribution of "The OPDX Bulletin" are granted as long as KB8NW/OPDX/BARF80 receives credit. ** To contribute DX info, please send via InterNet Mail to: <kb8nw@barf80.nshore.org> OR <kb8nw@arrl.net> OR <kb8nw@hotmail.com> Information can now be faxed to the following phone line at: 1-419-828-7791 (F A X only!) /EXIT -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
