Has anyone created a MS Access database that can retreive xml data? Please let me know if you have anything you would share with me. Thank You
MS Notepad can retrieve data. MS Access would not be my first choice for working with XML files. Especially when HTML would work across platforms. Have you tried to import the data ? That should work. Good Luck.
You question isn't exactly clear. Are you asking... if you can query / insert XML into an Access database? Actually storing XML inside of an Access database? Using Access to query / write to external XML files? There are many options out there. Access has import functions that can import XML files. I haven't used Access is probably close to 15 years, so I'm not super familiar with any of it's newer capabilities, but Googling Access and XML does return a lot of information.
