ad: Flexradio-1
Icom IC-705, IC-7300 and IC-9700 Waterfall Setup for Weak Signals
Discussion in 'Amateur Radio News' started by VK7HH, Oct 8, 2020.
  1. EA6VY
    EA6VY Premium Subscriber QRZ Page
    ThanX for such good tips !!
  2. VK7HH
    VK7HH Ham Member QRZ Page
    Thanks for the comments. Glad that it's helped some here.
  3. PA0MHS
    PA0MHS Ham Member QRZ Page
    As long as the entire receive chain remains within its dynamic range (no overload and RF noise higher than noise floor of RX) it makes no difference.
    Reading all responses to this video makes me realize a two things:
    • Many hams don't read manuals
    • Many hams seem to fear playing with their radios and change settings to see what they accomplish.
    W8LGZ likes this.
  4. WA1KPD
    WA1KPD XML Subscriber QRZ Page
    Excellent, thank you very much for both videos!
  5. BH4LLP
    BH4LLP Ham Member QRZ Page
  6. K7GYB
    K7GYB XML Subscriber QRZ Page
    You state the obvious which really isn't saying much... Of course, an operator is going to optimize their settings so their RX is above the noise-floor if possible. Furthermore, if it truly "makes no difference... " then there wouldn't be a REF option on Menu <2> in the first place. I'm always using it and know exactly what it does and fear no aspect of my radio, and that's including the manual. There are times you want to be able to see the weaker signals a bit more clearly, or diminish the footprint of stronger nearby signals without adjusting the RFG once it and other settings are optimally set. It is no different than adjusting the "contrast" button/knob on your old CRT tube screen or using the contrast or brightness feature in your phot0 editing software. It even says as much on pg./section 5-5 of the IC-7300 Full Reference Manual.
    W8LGZ likes this.
  7. CX5CDV
    CX5CDV Ham Member QRZ Page
    Mal lo mio,logre el color Limon amarillo nada mas,a pesar de tener el 7300 hace 1 año,me cuesta tocarlo o maniobrar con el,de todos modos gracias.
    mis un gran equipo,pero tengo que aprender mucho su configuracion,saludos desde Uruguay.-
  8. HL2INJ
    HL2INJ Ham Member QRZ Page
    Korean amateur building
  9. VK4DCM
    VK4DCM Ham Member QRZ Page
    Does anyone know how to reduce the spectrum scope lines {height it a waste of space on the screen.
  10. K7GYB
    If you're asking about the 7300, then I'm pretty sure the answer is that you are not able to reduce the number of lines on the spectrum scope grid. You can reduce the size of it proportionally by pressing the "M.Scope" hard-button under the color display which then gives more room for other features like the swr/alc/comp bar displays (press and hold the bar display above the spectrum display after activating the mini-scope to see bars) but as far as I can see, there is no option to modify the grid.
