ad: MorseTP-1
Easy Raspberry Pi Build Version 2
Discussion in 'Amateur Radio News' started by KM4ACK, Feb 28, 2020.
  1. KM4ACK
    KM4ACK Ham Member QRZ Page
    KG4CWC, VK2JI, W6IR and 2 others like this.
  2. VK2JI
    VK2JI Ham Member QRZ Page
    Nice video Jason. Thanks for creating the script and these instructions, it's far easier to understand when you can see what is to be done!
    Coincidentally the British National amateur radio Society - the RSGB has just released a new paper (or Kindle) book called "Raspberry Pi Explained for radio amateurs", which, for someone starting really from the beginning, along with your script, Jason should get most Hams going nicely with the RPi !
    https://www.rsgbshop.org/acatalog/Online_Catalogue_What_s_New_26.html
    73 and thanks again - Ed
    KM4ACK likes this.
  3. W5EKG
    W5EKG Ham Member QRZ Page
    Loaded and working. Thanks for the build! 64475D94-36C5-46F2-9646-293A53BD65D4.jpeg
    N0BML, KM4ACK, VK2JI and 2 others like this.
  4. KM4ACK
    The small screen is a nice touch! 73
    W5EKG likes this.
  5. K9JPT
    K9JPT Ham Member QRZ Page
    I enjoyed watching the video on this and I like working with Raspberry pi. How would a noob use all this? Right now I'm woking with S-star and DMR and on Friday I intend to build a APRS iGate with a raspberry pi. Thank you & 73 K9JPT
  6. W3CKL
    W3CKL Ham Member QRZ Page
    I'm eager to give this a go, but honestly, have no idea what I'd do with it. I have a Fusion capable HT. Could this be used as a hotspot for it?
  7. K9JPT
    I got this up and running on my own! This is a totally awesome product and Jason, the developer, has created something very special for the amateur radio community. Using this build I got an iGate up and running and it's slamming with traffic! AND it allows me to enjoy much more the APRS features of my Kenwood TH-D74A. This package is loaded with all sort of goodies that you just got to install it. 10 stars!!!
    KM4ACK likes this.
  8. K9JPT
    What command are you running to have both screens running simultaneously? Thank you!
  9. W5EKG
    You have to go into your pi config.txt file, scroll all the way to the bottom and change the resolution back to at least 800x600. The small screen changes to a low resolution which won’t work with the hdmi port. Changing it back to a higher resolution will give you your hdmi port back and dual monitor function without having to download programs, etc
  10. K9JPT
    I tried this and it did not work. The only setting I found controlled the width and height toward top. Did I miss something? The proper way to open config.txt is by running the command line sudo nano config.txt :)
    Also my LCD is a model MHS35. To run HDMI I must run
    chmod -R 755 LCD-show
    cd LCD-show/
    sudo ./MHS35-show
    To get the smaller screen size back I run
    cd LCD-show/
    sudo ./LCD-hdmi
    What I would like the most is an 'on' 'off' switch that would kill power to the LCD via GPIO. Or a simple script that could do the same.
  11. W5EKG
    I originally said 800x600, but meant 800x480.
    Try this. Open terminal and type-
    sudo nano /boot/config.txt
    It should open this
    scroll all the way to the bottom and change “hdmi_cvt” to 800x480
    Hope this helps!
  12. K9JPT
    Thank you for the detailed description! Sadly, under [all] only the first two lines appear and nothing more.
    Are you running a Raspberry pi 3 like me? Or is yours a 4? We both used Jason's package so it's odd the same files aren't available.
    I found this at
    https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
    Note that this simply creates the mode (group 2 mode 87). In order to make the Pi use this by default, you must add some additional settings. For example, the following selects an 800 × 480 resolution and enables audio drive:
    hdmi_cvt=800 480 60 6
    hdmi_group=2
    hdmi_mode=87
    hdmi_drive=2
    However, I also came across this:
    ignore_lcd
    By default the Raspberry Pi LCD display is used when it is detected on the I2C bus. ignore_lcd=1 will skip this detection phase, and therefore the LCD display will not be used.
    display_default_lcd
    If a Raspberry Pi DSI LCD is detected it will be used as the default display and will show the framebuffer. Setting display_default_lcd=0 will ensure the LCD is not the default display, which usually implies the HDMI output will be the default. The LCD can still be used by choosing its display number from supported applications, for example, omxplayer.
    Reading "display_default_lcd" leads me to believe that when HDMI is default then that monitor will be working at the shack and when I go mobile with the unit the LCD should boot up as the default (hdmi) is not available?
  13. W5EKG
    That is interesting. I am running the Pi4, but im unsure why that would have a different config.txt file.
  14. K9JPT
    Hi all! Is this thread still being monitored? I got a question I'd like to ask. I want to see time & date stamps of the traffic taking place over my iGate. I currently start Direwolf with the command 'direwolf -t 0' But I was also using 'direwolf -p -t o -L ~/Desktop/direwolf.log'. The problem with the later is that I can't send messages or beacons. Direwolf appears to just listen and write traffic to the direwolf.log file. When I use 'direwolf -t 0' I can do the messaging and everything else but I have no log of traffic. Am I missing something in the command? Thanks 73 K9JPT
