ad: LZQSLprint-1
Download JT65-HF1051.zip software
Discussion in 'Amateur Radio News' started by IZ4CZL, Jun 8, 2010.
  1. K4EEZ
    K4EEZ Ham Member QRZ Page
    ! D:\HAM RADIO Goodies Vol 1\Ham Radio_Goodies\Digital and Satellite programs\Jt65_HF\setupJT65-HF1051.zip: Unexpected end of archive ?
  2. IZ4CZL
    IZ4CZL Ham Member
    <img src="http://www.iz4czl.ucoz.com/JT65-HF_v1051-2.jpg" border="0" alt="" />
    Hi all,
    JT65-HF works JT65A as WSJT or Multipsk but it's the only that receive and decode all trasmissions made in the same minute.
    So if you want you can segle to answer the CQ you prefer among all and don't loose the small DX signal
    when the band is busy or you get QRM from other DIGI modes trasmission.
    JT65-HF also has bandwidth filters that you can set for the best RXing and you also can segle among single and multi decoder.
    I think is the best way for Terrestrial JT65A and you can download free for HAM use on:
    73 de Alex, IZ4CZL
  3. W4HM
    W4HM Ham Member QRZ Page
    160 Meter JT65A
    Hi Steve that would be great! I have my low full wave loop up for summer 160 meter operating and we should be able to have a QSO between FL and NH.
    Do you get on the http://jt65.w6cqz.org JT65A chat room? We can meet there and coordinate a QSO from there. I would recommend a QSO on 1807 kc USB instead of 1838 kc USB. 1838 kc is a very busy frequency with CQ.
    If you don't get on the chatroom email me directly at nz4o@arrl.net and we can try this evening.
  4. W4HM
    CW Versus JT65A
    The JT65A mode was originally for EME (moon bounce) work but recently was adapted for HF DXing. It really is an amazing mode for weak signal work. I've had QSO's with hams whose signals were as weak as -30 below the noise level.
    Since April I have worked 18 DXCC entities and 16 states, all with 1-4 watts on 80-6 meters. I think CW and JT65A are a dead heat as far as very weak signals getting through the QRM and QRN. However you don't need a computer to work CW.
    I have been a ham since 1989 and have always been a CW operator, a ham with a 20 wpm CSCE from the W5YI VE organization. However by 2003 I was so disgusted by the behavior of hams on SSB phone and to a lesser extent on CW that I was ready to sell all of my equipment.
    Then I discovered the digital modes, an arena where hams are still gentlemen and a brotherhood exists. I started out with PSK31, then MFSK16, RTTY and Olivia. At one time or another I've worked just about every digital mode out there.
    Without the digital modes I would have not renewed my ham ticket in 2009.
  5. KC2UGV
    KC2UGV Ham Member QRZ Page
    Who would have thought a digital mode would be as controversial as politics...
    inb4tl...
  6. K9ZMD
    K9ZMD Premium Subscriber QRZ Page
    Very astute, Fred. :rolleyes: Last night, with a little time on my hands, I downloaded the program & set it up for receive only. Wow, perfect copy of multiple signals on 14.076 (some I couldn't even see on the waterfall)! Very slick radio fun for those limited to QRP & stealth antennas. Kind of a slow pace, though (like watching paint dry), but otherwise just as much related to "communication" as this fictional series of CW transmissions: "B1GDX QRZ? WD8KNI AGN? WD8KNI WD8? WD8KNI WD8KNI WD8KNI 5NN R TU 599 WD8KNI B1GDX QRZ?" :D
  7. W4PG
    W4PG QRZ Lifetime Member #279 Platinum Subscriber Life Member QRZ Page
    Looks kind'a cool!! Just downloaded and set it up and it receives fine. I can't make the PTT work, however. Run PSK through HRD DM 780 with no problem, PTT on COM4. Can't get this program to key the rig, however.
    Yes, I did fill in my callsign!! ;)
    Back to trouble-shooting!!
    ..............Bob
  8. W4PG
    Aaarrggh!!
    Had a COM port problem!! All is well now!!
    ............Bob
  9. AB1JM
    AB1JM XML Subscriber QRZ Page
    Want to give it a try? I am on 20m now..
    de AB1JM
  10. IZ4CZL
    IZ4CZL Ham Member
    Hi Bob,
    You have to run another COM port for the PTT and not the same of HRD.
    Anyway you can TX using the VOX only without COM port.
    W4PG de IZ4CZL Alex, GL es 73
  11. G4ILO
    G4ILO Ham Member QRZ Page
    The software is nice, I've tried it, but personally I can't see the point in using this mode to take 6 minutes to exchange minimal information with people you could easily have a proper contact using PSK31 or whatever, which is what seems to happen most of the time. JT65 was designed for EME or something where signals really are weak and a proper contact just isn't possible most of the time. Why use it on HF? Beats me.
    But is it any less of "communication" than hollering your call over and over again until the DX replies "G4ILO you're 59"?
  12. W4PG
    OK . . . I"m going to try a CQ and see what happens!!
  13. AB1JM
    Had to step away from the shack for a moment but your CQ came through fine here.
    AB1JM
  14. W4PG
    I actually was in QSO with a European when my breaker tripped!! 1st QSO and that had to happen. Forgot to write his call down!! I forgot that I can't run the window A/C while everything is full-bore . . . apparently even when running only 10 watts!!
    ............. Bob <---------turning off ceiling fan and other unnecessary appliances!!
  15. IZ4CZL
    IZ4CZL Ham Member
ad: Schulman-1
