Coax Loss vs Connector Loss
Discussion in 'Amateur Radio News' started by VK6FLAB, Mar 15, 2018.
  1. N8CMQ
    N8CMQ XML Subscriber QRZ Page
    Why change, what do you have to gain?
    KK5R and K1FBI like this.
  2. N8CMQ
    Actually, the motorola connector has a longer pin. I have an adaptor that works with both motorola AND rca connectors.
    NL7W and KK5R like this.
  3. KM1H
    KM1H Ham Member QRZ Page
    The common auto radio connector/plug has worked well for about 80 years and does not go intermittent. A modern crimp version for RG-58/8X size cables would be far better than the RCA and possibly the BNC up to VHF.
    Carl
    KK5R likes this.
  4. KK5R
    KK5R Ham Member QRZ Page
    On some adapters for converting to the UHF connector, instructions in the kit are to cut off the long pin about 3/8-in. This instruction is from both use in MFJ kits and the Ramsey kits. Radio Shack sold the adapter. I found that on the Ramsey kit I built, it was not necessary to cut off the pin. It depends mainly on which type of connector is used on a specific radio as to whether the pin had to be cut. Some connectors on the radio had a problem of components mounted right back of the connector and if the long pin adapter were used on them, it could contact some other component of the wire soldered to the connector itself. This is why the instruction to cut off the pin to a shorter length.
  5. KK5R
    The Philco designed auto radio style connector is indeed a good connector and did not require a twist-shell to secure the connection. Some lip-mount Hustler mobile mounts used this kind of connector I only found one failure using this on my car and it was in the coax at the connector, not the connector itself. It is relatively long but it about the size of RG-58/59 so it did not present a bad transition from coax to connector. Most of them used a paper/fiber phenolic insulator so there is relatively little danger of insulation deterioration.
    If you take a Heath style connector cable used on many of those QRP rigs, and it is pushed into the Philco auto radio connector, it will fit and can be used as a transition from a car radio to another kind of antenna, for example. It is a more dependable connection from the cable/coax to the connector than when using the male Philco connector where it comes to connecting the outer shell because many of those auto radio cables from the antenna does not use soldering to the coax but merely depend on dry contact without soldering. Such technology, not soldering the braided shield to the connector, invites eventual bad-connection problems. Using the Heath style connector eliminates this weakness.
    KM1H likes this.
  6. WP2ASS
    WP2ASS Ham Member QRZ Page
    You must be on the design team for the iPhone charging port.
  7. WP2ASS
    The spade terminals on the end of my open wire line work fine, thank you.
  8. KR3DX
    KR3DX Ham Member QRZ Page
    What's an iPhone?
  9. KR3DX
    So do the ones on MY open wire feedline. However, all of my EQUIPMENT is connected together with coax.
  10. W2ILP
    W2ILP Ham Member QRZ Page
    Professional tests for RF loss are made by using what is called a "network analysis" test set-up. This consists of signal generators which can scan RF bands of interest or spot RF frequencies. The generators feed a 50 ohm hardline arm, which is connected to the cable or connectors being tested. Another hardline arm goes to RF measuring devices which can be precision RF meters capable of operating flatly at the frequencies being tested for or leveled and calibrated modern digital storage displays that are scanned in sync with scanning inputs. When the two arms are connected directly to each other zero loss is referenced. In my experience using network analysis set-ups the coax cable losses measured for coax pretty much agrees with book values to be found in "Reference Data for Radio Engineers" or ARRL manuals. Now I'll talk about coax connectors. Tests are usually made with a pair of connectors, male and female. This is what engineers. refer to as INSERTION LOSS. There is always some finite insertion loss involved. It is usually less than 0.25 dB. This is not a very significant loss in most cases but it can be significant at UHF or microwave frequencies or for those who want to get every watt out of a QRP transmitter.
    KR3DX likes this.
  11. WY7BG
    WY7BG XML Subscriber QRZ Page
    The tests didn't measure the loss with sufficient resolution.
    In my experience, connectors take about .1 dB - less than the resolution of the bandscope used in the test.
  12. KR3DX
    Thanks for accurate info from an engineering perspective. What type of connector did you measure? There are situations where a station installation may have a dozen or more connector pairs between the xcvr and antenna. The xcvr connection, input and output of the amp, input and output of the antenna tuner, input and output of the wattmeter, input and output of the antenna switch, input and output of the static arrestor, input and output of the balun, and the antenna connection. That adds up to 14 connector pairs. A loss of .25db per connector pair could easily add up to 3db or more loss for the entire station, both on receive and transmit. I would like to minimize this loss as much as possible.
  13. W6RZ
    W6RZ Premium Subscriber QRZ Page
    A loss of 0.25 dB for a connector at HF doesn't make sense. At 1500 watts, it would dissipate 84 watts. But clearly folks run 1500 watts all the time without their connectors desoldering themselves.
    NL7W likes this.
  14. KR3DX
    W2ILP clearly referenced "insertion loss". Run 1500 watts CONTINUOUS power for a few minutes, then see how warm you connectors are.
  15. W6RZ
    There was already a good post on this thread where the dissipation of connectors was measured.
    NL7W likes this.
