ad: Schulman-1
  1. WB9SBD
    WB9SBD Ham Member QRZ Page
    Joe WB9SBD
    Mission Director
    Near Space Sciences
    nss@mwt.net</small>
  2. KA0HCP
  3. W9DTC
    W9DTC Ham Member QRZ Page
    TRANSMISSION DETAILS:
    ANTENNA: Vertical Wire Dipole
  4. K8MHZ
    K8MHZ Ham Member QRZ Page
  5. WB9SBD
    BUT!!!
    Joe
  6. K5CO
    K5CO Ham Member QRZ Page
    Sounds like fun.
    K5CO
  7. KC9XG
    KC9XG Ham Member QRZ Page
    Bill KC9XG
  8. WB9SBD
    See Post #5?
    Joe
  9. KC9XG
    Bill KC9XG
  10. K0RGR
  11. WB9SBD
  12. N7LOH
    N7LOH Ham Member QRZ Page
  13. KG4FET
    KG4FET Ham Member QRZ Page
    K0RGR
    73 es God Bless America
    Sandor KG4FET
  14. WB9SBD
    Joe
  15. K2HAT
    APRS on the balloon?
ad: Flexradio-1
