ad: Retevis-1
XML error
Discussion in 'QRZ XML Logbook Data' started by CE3DNP, Jan 8, 2016.
Tags:
  1. CE3DNP
    CE3DNP Ham Member QRZ Page
    For one of my own applications in vb.net 2015 I have been programming the update of a database for ce stations. Based on indications from this same place everything it seems fine until I unexpectedly returns an XML program stops and error. This is completely random and as much data as 6000, when it ends after about 10 minutes, the error has jumped about 6 to 7 times.
    Key is checked before each call: if key = "" then new key. So, it seems that is not a problem with the key.
    Any ideas or suggestions?
  2. KG7FIU
    KG7FIU Ham Member QRZ Page
    Just a general suggestion. If you're not already doing it, you could try implementing exception handling using a "try" / "catch" block in your code. You can look at the error message text within the "catch" block and see what kind of error is getting raised. If the error is significant, try to handle it. If the error doesn't look significant, then you can disregard it and keep on processing...
ad: M2Ant-1
