ad: wmr-1
Using the logbook API in VB.NET (or C#)
Discussion in 'QRZ XML Logbook Data' started by G4IJE, Jan 26, 2024.
  1. G4IJE
    G4IJE XML Subscriber QRZ Page
    I have written my own logging software and I would like to be able to insert a new QSO into my QRZ logbook using VB.NET (Winforms, Framework 4.8). This is my code:
    Imports System.Net.Http
    Sub PostLogEntry()
    Dim postString As New StringBuilder
    postString.Append("KEY=AAAA-BBBB-CCCC-DDDD") ' Not showing my actual key!
    postString.Append("&")
    postString.Append("ACTION=INSERT")
    postString.Append("ADIF=<call:5>G9ZZZ<gridsquare:6>JO00FW<mode:3>FT8<rst_sent:3>+10<rst_rcvd:3>-05<qso_date:8>20240121<time_on:6>120000")
    postString.Append("<qso_date_off:8>20240121<time_off:6>120100<band:2>6m<station_callsign:5>G4IJE<my_gridsquare:6>JO01HP<eor>")
    Using client As New HttpClient
    Dim endpoint = New Uri("https://logbook.qrz.com/api")
    Dim PostData = New StringContent(postString.ToString)
    Dim result = client.PostAsync(endpoint, PostData).Result.Content.ReadAsStringAsync().Result
    MessageBox.Show(result.ToString)
    End Using
    End Sub
    The result returned is STATUS=AUTH&RESULT=AUTH&REASON=invalid api key
    I have contacted QRZ support and they have allocated a new API Key, but it has not helped so perhaps my code is wrong. Are there any logbook developers out there using VB or C# with the QRZ API that can help me get this right?
    Thanks and 73,
    Paul G4IJE.
  2. KG4LAC
    KG4LAC Ham Member QRZ Page
    While not specifically addressing the api key failure there is no need to have the stringbuilder on multiple lines.
    Dim postString As New StringBuilder("KEY=AAAA-BBBB-CCCC-DDDD&ACTION=INSERT&ADIF=<call:5>G9ZZZ<gridsquare:6>JO00FW<mode:3>FT8<rst_sent:3>+10<rst_rcvd:3>-05<qso_date:8>20240121<time_on:6>120000<qso_date_off:8>20240121<time_off:6>120100<band:2>6m<station_callsign:5>G4IJE<my_gridsquare:6>JO01HP<eor>")
    The variables, for the most part are not typed. Probably getting default variants instead of the correct object type.
    For example, change Using client As New HttpClient to Using client As HttpClient = New HttpClient()
    Fix the other Dims to properly type.
    Dim endpoint
    Dim PostData
    Dim result
    For example, Dim result as HttpResponseMessage
    Fix the other Dims.
  3. G4IJE
    The StringBuilder is just to make the code more readable. It also made it easy to change the ampersand separator to a semi-colon, which is mentioned in the API spec. It didn't help though.
    VS 2022 prompts that "Object creation can be simplified" when using verbose definitions like "Using client As HttpClient = New HttpClient". I tried anyway of course but it still gave the same error.
    Thanks for your input. 73, Paul G4IJE.
  4. KG4LAC
    My point with the stringbuilder -- there is no need for the numerous appends.
    Could have continued the lines with & for example
    Dim postString As New StringBuilder("KEY=AAAA-BBBB-CCCC-DDDD&ACTION=INSERT&ADIF=<call:5>G9ZZZ" &
    "<gridsquare:6>JO00FW<mode:3>FT8<rst_sent:3>+10<rst_rcvd:3>-05<qso_date:8>20240121" &
    "<time_on:6>120000<qso_date_off:8>20240121<time_off:6>120100<band:2>6m<station_callsign:5>" &
    "G4IJE<my_gridsquare:6>JO01HP<eor>")
    Did you properly declare the other variables?
  5. KG4LAC
    Where is the QRZ api info? I want to review/analyze.
  6. G4IJE
  7. KG4LAC
  8. KG4LAC
    After fixing the http encoding and properly typing all dims fix the following
    from
    to
    result = client.PostAsync(endpoint, postString.ToString).Result.Content.ReadAsStringAsync().Result
  9. G4IJE
    I lost track of the URL encoding somewhere along the many iterations of the code. I have seen so many different ways of doing an HTTP POST it has become something of a blur!
    I have tried yet another method (suggested by Google Bard) but still get the same API key error message. Here's the code anyway:
    Dim dataToPost As String = postString.ToString
    Dim encodedData As String = WebUtility.UrlEncode(dataToPost)
    Dim request As HttpWebRequest = CType(WebRequest.Create("https://logbook.qrz.com/api"), HttpWebRequest)
    request.Method = "POST"
    request.ContentType = "application/x-www-form-urlencoded"
    request.ContentLength = encodedData.Length
    Using stream = request.GetRequestStream()
    Dim bytes As Byte() = Encoding.ASCII.GetBytes(encodedData)
    stream.Write(bytes, 0, bytes.Length)
    End Using
    Dim response As HttpWebResponse = CType(request.GetResponse(), HttpWebResponse)
    Using reader As New StreamReader(response.GetResponseStream())
    Dim responseText As String = reader.ReadToEnd()
    MsgBox(responseText)
    End Using
    I may try QRZ support again, just in case there really is an issue with my account.
    Thanks for your help. 73, Paul G4IJE.
  10. KG4LAC
    Don't need the stream!
    Reason to use httpencoding as the text has characters giving HTML problems. For example, <, >, etc.
    These steps are unnecessary and unneeded.
    System.Web.HttpUtility.HtmlEncode(postString.ToString) when ready to send. No need to put into 1 string and then another string.
  11. KG4LAC
    Paul, I'm willing to work on this item here or directly to get this working for you.
  12. G4IJE
    I have finally got something that works:
    Sub PostLogEntry2()
    Dim encodedData As String = HttpUtility.UrlEncode("KEY") & "=" & HttpUtility.UrlEncode("33BB-143B-2727-ACEA") & "&"
    encodedData &= HttpUtility.UrlEncode("ACTION") & "=" & HttpUtility.UrlEncode("INSERT") & "&"
    encodedData &= HttpUtility.UrlEncode("ADIF") & "=" & HttpUtility.UrlEncode("ADIF=<band:2>2m<mode:3>SSB<call:5>G9ZZZ<qso_date:8>20240128<station_callsign:5>G4IJE<time_on:4>1130<eor>")
    End Using
    End Using
    End Sub
    I can now tidy the code up a bit and incorporate it in my logging software.
    Thanks for your help and interest. 73, Paul G4IJE.
  13. KG4LAC
    Really don't need to individually encode the string.
    Dim encodedData As String = HttpUtility.UrlEncode("KEY") & "=" & HttpUtility.UrlEncode("AAAA-BBBB-CCCC-DDDD") & "&"
    EDIT THE POST TO REMOVE THE API KEY!
    Why 2 ADIF in the above?
    This will work
    "KEY=AAAA-BBBB-CCCC-DDDD&ACTION=INSERT&ADIF=<band:2>2m<mode:3>SSB<call:5>G9ZZZ<qso_date:8>20240128<station_callsign:5>G4IJE<time_on:4>1130<eor>")
    Remember strings are immutable. This means a new string object is created if the string is changed. This is considered as "expensive".
    https://forums.qrz.com/index.php?threads/using-the-logbook-api-in-vb-net-or-c.898570/#post-6779348
    If a string value changes, then use the stringbuilder.
  14. G4IJE
    Hopefully no-one noticed my deliberate mistake ;-) My API Key has now been changed.
    Copy/paste error with the duplicate ADIF but it worked anyway.
    73, Paul.
  15. KG4LAC
    Paul,
    Unfortunately, your API key is still shown in post #12. Might need to get QRZ admin involved.
    Kraig
