ad: AbAuRe-1
ISS Repeater Tips
Discussion in 'Amateur Radio News' started by G4TUT/SK2022, Feb 7, 2008.
  1. G4TUT/SK2022
    G4TUT/SK2022 Ham Member QRZ Page
    ISS Repeater Tips
    Miles Mann WF1F has published these tips on how to use the ISS 70cm to 2 metre FM repeater.
    How to use the ISS Cross Band Repeater
    By Miles Mann WF1F
    MAREX-MG (Manned Amateur Radio Experiment, North American Division)
    What is a Cross Band Repeater:
    The Kenwood D700 on ISS supports several modes, including a mode called Cross Band Repeating. It allows signals on one band (70cm 437.800) to be received and simultaneously transmitted on another band (145.800 in this example). This combination is called Mode B in the satellite world.
    When the radio is in this mode, Terrestrial stations can talk to other ham using most standard dual band FM transceivers, just like using a Mono-Band FM Repeater.
    Since the Repeater is 220 miles altitude, it will have much greater range than a typical terrestrial repeater, up to 1400 miles in distance.
    When is the Cross band Repeater turned on:
    There is no set schedule. Most of it depends on access to the ISS crews. If there a slight gap in the crew schedule we can sometimes get the Repeater Mode turned on. It should be noted that the radio has not been modified for operations in Zero Gravity. All electronics run hotter inside the Space Station. The Cross Band repeater modes does put more thermal stress on the radio than other modes.
    What Frequencies do I use:
    The Cross Band repeater mode listens on 437.800 MHz FM, and will Transmit on 145.800 MHz FM. You will need to compensate for Doppler, especially on the Uplink side 437.800. On the 2-meter band 145.800, if you can not compensate for Doppler, do not worry about it. Most of the time you will be able to hear the down link signal fine. The Doppler on 145.800 is only 3.6 kHz maximum. Your stock FM receiver will still be able to hear ISS when it is 3khz off frequency.
    The 437.800 uplink is a completely different story.
    You will need to compensate for Doppler, every minute of the pass. If your radio has only a 5khz you will need to time your transmissions for when your Doppler error is less than 3khz different from you calculated uplink frequency. The closer your uplink frequency matches the receiver’s frequency on the repeater, the stronger you signal will be into the repeater.
    For All mode Users. If you can pre save these split frequencies in to memory channels that will make life much easier during the short 10 minute ISS pass window.
    For VFO users, this chart will help you sweep across the 70cm band and will help you stay on the correct uplink frequency.
    Down RX Up TX
    1 145.803 437.790
    2 145.803 437.793
    3 145.802 437.795
    4 145.801 437.798
    5 145.800 437.800
    6 145.799 437.803
    7 145.798 437.805
    8 145.797 437.807
    9 145.797 437.810
    For users with Radio designed for 5 kHz channels steps, program in the following channel splits.
    Down RX Up TX
    1 145.800 437.790
    2 145.800 437.795
    3 145.800 437.800
    4 145.800 437.805
    5 145.800 437.810
    How to I calculate Doppler:
    Most satellite tracking programs will calculate the Doppler frequency error for a satellite. Here is an example from InstaTrack. I assigned the satellite ISS, the radio frequency of 437.800. The display reports will now show me the approximate Doppler error for a given time.
    In this example, at 22:06 UTC time, the ISS will be in range of my location and the Doppler on 437.800 will be +10,240 Hz. In order for my signal to line up with the receiver, I need to transmit 10,240 Hz LOWER in frequency to compensate for Doppler + Positive shift in my frequency (Due to the 17,500 mile per hour speed of the Space Station).
    So instead of transmitting on 437.800, I will transmit on 437.790.
    Here is an example of a typical
    3. ISS (ZARYA)
    UTC Date Time Azim/Elev Range Doppler
    03Feb2008 2206 237/ 4 1748 +10,240
    03Feb2008 2207 238/ 9 1372 +10,182
    03Feb2008 2208 238/ 16 1002 +10,002
    03Feb2008 2209 240/ 30 652 +9,448
    03Feb2008 2210 250/ 64 387 +7,184
    03Feb2008 2211 47/ 55 420 -897
    03Feb2008 2212 53/ 27 711 -7,876
    03Feb2008 2213 55/ 15 1066 -9,600
    03Feb2008 2214 55/ 8 1438 -10,046
    03Feb2008 2214 56/ 3 1815 -10,195
    --------------end of pass----------------------
    What do I need for Hardware:
    Repeaters contacts can be made with a true dual band FM transceiver and Zero Gain antennas or better. Always keep you transmitter power to a minimum. An All mode system with true full-Duplex works the best. Just make sure you have your headphones on, to reduce the Feed back loop.
    Azimuth and elevation beam antennas, will of course work the best.
    The D700 will typically be running 10 watts while in cross band mode.
    You do not need any CTCSS tones to access the ISS Repeater. The repeater is very sensitive to Audio levels. Keep your microphone audio levels turned down Low. If you do not have a Level adjustment, make sure you speak softly. Loud audio will just turn into pure distortion.
    When will ISS be in range of my house:
    You will need to do some more research here too.
    Either use some web tracking programs such as are on the NASA web page or buy your own tracking program. If you are using your own tracking program, keep the data (KEPS) current. For ISS the data must be less than 2 weeks old.
    The Space Stations orbit changes daily, you will need to learn about these predictable changes. Each day the first pass of the day will have shifted by approximately 40 minutes earlier in the day. In a few weeks, the first orbit of the day will be around Midnight local time. The whole orbit cycle of ISS repeats approximately every 8 weeks. You will need to learn how to take advantage of when ISS is in a good position. It may mean that you may have to get out of bed at a strange time for a short Repeater contact.
    It is possible to see the Space Station with just your eyes on a good pass. The NASA web pages are a good source of information. From this web page below you can select your city and find out when the Space Station will be visible near your home.
    City visibility page: http://spaceflight.nasa.gov/realdata/sightings/
    General Tracking information:
    http://spaceflight.nasa.gov/realdata/tracking/index.html
    ISS QSL:
    The ARISS Europe team has posted a QSL address for ISS.
    http://www.rac.ca/ariss/oindex.htm#QSL
    So spread the world.
    73 Miles WF1F
    MAREX-MG
    New MAREX Web pages:
    Check out our future ISS Projects and tips on how to use the Chat room on ISS.
    http://www.marexmg.org/
    Until we meet again
    DOSVIDANIYA Miles WF1F
    Don't wait all week for the news!
    Amateur Radio News - updated daily - 365 days per year
    Get our News Headlines for your Website:
    http://www.southgatearc.org/rss/index.htm
    Send Us Your News Items:
    http://www.southgatearc.org/news/your_news.htm
  2. KB3PXR
    KB3PXR Ham Member QRZ Page
    You really need to correct that typo under the doppler section, this is a family forum.
  3. K4LFP
    K4LFP Ham Member QRZ Page
    Thank you for writing this in plain English. I will print this out and attempt some contacts. Alan
  4. KC2ESD
    KC2ESD Ham Member QRZ Page
    ISS Repeater Off
    I've heard the ISS repeater for the last week. Last night I listen to 145.800 while the ISS was making a pass. Nothing heard. I think the repeater is off due to the launch of the Space Shuttle Atlantis today at 19:45hrs UTC.
    Just letting every one know.
    Rick KC2ESD
  5. KC2ESD
    Repeater still off
    I just checked again on 145.800Mhz at 15:31EST (20:31UTC) and I did not hear the repeater. I checked for the pass on the n2yo website to make sure I had the right time.
    Also the Space Shuttle Atlantis lifted off on time at 19:45UTC and it is on its way to the ISS with the docking on Saturday. You can go to http://www.space.com for more info.
    73 de Rick KC2ESD
  6. 9K2HM
    9K2HM Guest
    hi
    thanx alot
  7. 9K2HM
    9K2HM Guest
    hi
    can i make crose band in icom ic- v8000 or not ???????
  8. K5OP
    K5OP Ham Member QRZ Page
    9k2hm, the Icom IC-V8000 is a 2 METER radio only. You'll need a dual-band 2meter/70centimeter radio in order to talk through the ISS's repeater...
    Transmit on 437.8000 and Receive on 145.8000 mhz
  9. PD9FER
    PD9FER XML Subscriber QRZ Page
    ISS repeater is off because of safety reasons for
    progress docking (cargo ship).
    source pd0rkc
    Guess it will be on again after the STS 122 Columbus mission.
  10. KC2ESD
    Thanks for the info.
  11. K6WRJ
    K6WRJ QRZ Lifetime Member #492 Platinum Subscriber Life Member QRZ Page
    Can I hear the space station on a standard antenna? I have a 2 meter j-pole vertically polorized.
    I don't plan on transmitting but would like to listen.
    73 K6WRJ
  12. KC4UMO
    KC4UMO Ham Member QRZ Page
    Yes you can hear it on a vertical antenna.
    If you have a pre-amp it may help.
  13. KC2ESD
    The ISS can be heard with a HT near a window or outside.
  14. VE9SY
    VE9SY Ham Member QRZ Page
    Last Sunday it went directly overhead up here. We watched it go over and I had my hand held with a rubber duck. It was like listening to the local repeater. When I first heard it, it was off freq a bit due to to Doppler affect. But once it got closer wow. I was actually amazed!
  15. N3CRT
    N3CRT Ham Member QRZ Page
    ISS repeater mode- another tip
    Since its obvious listening to the downlink that the repeater is very sensitive to audio deviation and signal, I have had better luck getting in with Narrow FM mode.
    YMMV
    N3CRT FN20
ad: MLSons-1
