ad: TinyPaddle-1
How to correct CQ and ITU Zone Numbers?
Discussion in 'QRZ XML Logbook Data' started by N6DSC, Apr 17, 2021.
  1. N6DSC
    N6DSC Platinum Subscriber Platinum Subscriber QRZ Page
    How do I make permanent the correct CQ and ITU zone numbers for my station when I log a QSO. I know how to edit each individual contact. But when I log a contact it inserts the wrong CQ and ITU numbers and I have to go in and manually correct it on each QSO? I have when I automatically set up LoTW and send QRZ contacts to LoTW they had wrong CQ and ITU zone numbers. Any suggestions now I can correct the Numbers sent to LoTW?
    Thank you
    Duane, N6DSC
  2. JA6XZS
    JA6XZS Volunteer DX Helper Volunteer DX Helper Platinum Subscriber QRZ Page
    Hi Duane,
    Looks like you've already managed to correct it, right?
    Kaz, JA6XZS
    DX Helper, QRZ.com
  3. JA6XZS
    Thanks for a PM and all is ok with you now, Duane.
  4. N3IIG
    N3IIG XML Subscriber QRZ Page
    I have the same issue...care to share how you can bulk change the CQ and/or ITU Zone ?
    Tnx - N3IIG
  5. KP4SX
    KP4SX Ham Member QRZ Page
    Settings>Logbook Properties.
    It won't change previous contacts, though.
  6. N3IIG
    Thank you! To confirm ...there is no way to either export or otherwise bulk change like over 300 Q's?
  7. W4PG
    W4PG QRZ Lifetime Member #279 Platinum Subscriber Life Member QRZ Page
    You might want to post this query in the "Logbook Users Forum." I personally don't know a way to bulk change QSOs but someone in that forum may be able to help.
  8. WA2CB
    WA2CB Ham Member QRZ Page
    My logbook ran out a year ago. It would be nice to continue it. I changed the new end-date to Dec. 2043, but I don't know my CQ zone #, or where to find it? WA2CB. (I have high functioning autism, so I have learning issues)
  9. W4PG
    Check your own QRZ page and click on the "details" tab. You will see that your CQ zone is 5. You can also Google "CQ Zones" and you will see many different maps of the zones.
    ..............Bob
  10. WA2CB
    THANK YOU! I put the "5's" in there,& it works! WA2CB
  11. N1MRK
    N1MRK XML Subscriber QRZ Page
    Hi. I am trying to setup mu qrz logbook page to work with my outside log book.
    The outside log program wants a qrz code?
    Also , within qrz log book properties, what is an ITU zone? I need to fill this in.
    Thanku
    William
    Mulletbay1@comcast.net
  12. KP4SX
    Here is where you find your API key.
  13. KP4SX
  14. VE3ZZX
    VE3ZZX XML Subscriber QRZ Page
    Hi Bob,
    Same issue here. Based on your advise..
    I am told I am in zone 4. I have no reason to believe otherwise.
    In QRZ in the details page it is set at zone 5. I cannot make the change to 4 on that page as it is locked.
    When I go to settings > Logbook properties, I change the zone to 4. I then click save, and go back to the details tab to confirm, but the change was not made.
    Any thoughts on how to make the change permanently?
  15. W4PG
    Don't go to logbook properties. You set your CQ ZONE and ITU ZONE on your QRZ page. Log into QRZ then at the top right, click on your call sign then <yourcall> page. Then at the top right click on "edit." Go under the "callsign data" section then change the zone to the correct number, then hit save. This is NOT in the logbook setting, just to be sure, but in your QRZ PAGE.
    ................Bob
ad: M2Ant-1
