ad: Schulman-1
Dr. Ulrich Rohde: Electrically Short Antennas
Discussion in 'Amateur Radio News' started by AB4OJ/SK2024, Dec 24, 2020.
  1. SM0AOM
    SM0AOM Ham Member QRZ Page
    If it could be "done easily", tracking narrow-bandwidth front end selectivity would be used in all receivers, even cheap ones, and perhaps 80-90 % of my worries as a systems designer would be gone.
    The problem is just that RF selectivity with even a few percent bandwidth represents a major undertaking if it is expected to be frequency agile.
    This is why an R&S FK101 or Telefunken VS1800 cost "an arm and a leg".
    As systems engineers, we need to see the whole picture, and identify the areas where improvements provide most "bang-for-buck".
    I am not entirely convinced that concentrating on receiver performance only is the panacea for system performance issues. There is a balance point between the performance of the different components which make up a communications system.
    73/
    Karl-Arne
    SM0AOM
  2. KG7KVI
    KG7KVI Ham Member QRZ Page
    And I guess that is why the heterodyne receiver was born. Moving the signal to the filter instead of the filter to the signal.
    Just so I'm clear the "done easily" part is in the DSP and not analog.
    Dale
  3. PA0MHS
    PA0MHS Ham Member QRZ Page
    DHL just dropped off my copy of "Communications Receivers" by Dr. Rohde "and friends". 676 pages of bed-time reading :)
  4. KG7KVI
    For your 2m and 70cm bands unless you are talking mobile maybe a couple of repeater diplexers tuned wider and just use one side?
    edit
    I guess they a more band reject than band pass.
  5. N1UL
    N1UL QRZ Lifetime Member #303 Platinum Subscriber Life Member QRZ Page
    The duplexes are more carrier noise reject in the pass and, carrier notch at the Tx frequency and TX noise at suppression at offset of 5 MHz at UHF.
  6. N1UL
    correct, the notches eliminate hopefully the TX side band noise in the RX channel. As there are so many pagers and other services on top of the tall Marco Island buildings I always add one single pass band cavity for the RX frequency.
  7. N1UL
    For those of you who like to get an additional introduction of SDR technology problems and application and results please go over the attached presentation. I will make a much more technical 5 G related and SDR related presentation here availabl which I composed with members of the engineering staff of my company Rohde & Schwarz, Munich , Germany, once I solve the space upload problem here .
    PA0MHS and KO4LZ like this.
  8. PA0MHS
    Why not put it up on your own web site and provide a link here.
    73, Meindert - PAøMHS
  9. N1UL
    That’s a good option, but if my website has a problem, which can happen, then the access is lost. If it’s here, everything is together.
    I will come back on this issue. Thanks.
    73 de Ulrich
  10. N1UL
    Thanks to Fred LLoyd the very technical presentation is now found here :
    https://s3.amazonaws.com/files.qrz.com/downloads/UlrichRohde.IEEE.2019.pdf
    73 de Ulrich, N1UL
    PY2RAF, PA0MHS and W0PV like this.
  11. W1YW
    Kudos to Ulrich and R&S staff on producing this encyclopedic overview of 5G!
    If you don't see something you relate to, then keep on reading. It's there.
    Chip W1YW
  12. WA2LXB
    Thanks Dr. Rhode! Enjoyed your QRZ page and links as well.
    Hugh WA2LXB
  13. I0KQB
    I0KQB Ham Member QRZ Page
    m
  14. I0KQB
    Mr. Rohde
    Thanks fro your very interesting, clear and well done document, about the antennas.
    Greetings from Rome
    73's de Giovanni Francia I0KQB
  15. N1UL
    Thanks, ,73 de Ulrich, N1UL
ad: cq2k-1
