ARRL FILES REGULATION-BY-BANDWIDTH PETITION
Discussion in 'Amateur Radio News' started by AA7BQ, Nov 19, 2005.
  1. KY5U
    KY5U Ham Member QRZ Page
    I have looked for it, but never found it in comments by our digital experts. The thing I am looking for is a word that describes the real world signal conditions nearly 100% of the time. That word is "interference" as it pertains to bit error rates. I see alot of "lab" claims floating around but no mention of performance in the real world of S/I. I see conversations about occupancy rates, but no discussion of how far away in frequency a digital signal has to be from a SSB Analog Voice to offer the same or less interference than another neighborong Analog Voice SSB signal.
    Who here was mentioning the Pactor modem taking 200+ seconds to transmit a message that should have been done in less than 10 seconds? Obviously a result of interference...
  2. N5RFX
    N5RFX Ham Member QRZ Page
    AG4YO:"I see conversations about occupancy rates, but no discussion of how far away in frequency a digital signal has to be from a SSB Analog Voice to offer the same or less interference than another neighboring Analog Voice SSB signal."
    Charlie,
    Welcome back! I was gone last week on a cruise for my 25th wedding anniversary. I went through withdrawal without these discussions on QRZ. Anyway I would like to do some tests to answer your question quoted above. I think that analyzing the interference to SSB that offers the same or less interference is too subjective, so what I would like to propose is a test where several on the air SSB QSOs are sampled and then the frequency adjusted on the receiver until the signal effectively goes away. This could also be done with a digital signal. A digital signal that is readily available on 14.233 is DRM. There is also SSB analog voice on that same frequency. I did some quick testing and found that I had to move an average of 2.6 kHz from the perceived center frequency of a SSB QSO to eliminate the QSO according to my ear. I then listened to some DRM signals and performed the same task and found that I needed to move an average of 2.5 KHz to eliminate the DRM QSO according to my ear. Given some measurement error, I would say that both signals require equal spacing to eliminate an interfering QSO.
    Is this procedure acceptable, and if so how would you like to see it documented?
    Mark N5RFX
  3. AB0WR
    AB0WR Ham Member QRZ Page
    Mark,
    I'm sorry I haven't had the time to give this the attention it deserves.
    I am curious as to why your program shows a sine wave with a crest factor of 0db. Usually a sine wave is considered to have a voltage crest factor of about 1.41. (i.e. (1) / (.707) ) This would give a power crest factor of 3db (i.e. (1**2) / (.707**2) )
    This is not a PEP measurement because there is no modulation envelope but it is a crest factor.
    Let me know what you think is going on.
    tim ab0wr
  4. N5RFX
    Tim,
    The program does not show a crest factor of 0dB it shows a peak to average ratio of 0dB. I agree that there is no modulation envelope, but the PEP of a sine wave and the average power of a sine wave are equal. BTW to convert from peak to average ratio to crest factor, add 3 dB.
    Mark N5RFX
  5. KY5U
    Hi Mark,
    Yes, I had a great time with my sons and daughter at the graduation of my oldest son. Always miss amateur related things when I am gone, especially operating when I am away during the week. Gotta get my portable station going. On the interference issue:
    I accept that if given enough spacing, the different modes could co-exist. If you tune away from a digital signal and lose it from the ear at 2.5khz, then that would represent the proper edge for a co-channel SSB station. You would take that spot and add the 2.6khz for the SSB non interference and so, 5.1kHz away from your digital signal center frequency would be the interference free center frequency for the SSB QSO (give or take a khz for the effect of dimimishing signal at each end), right? That is perfect world.
    My question relates to co-channel digital on digital, digital on SSB, SSB on digital, and SSB on SSB interference numbers. Take a PActor III modem on the same frequency as another Pactor III modem and see how far you have to change frequency on one modem for both modems to work according to some minimum advertized standard. Do the same test for a Pactor III modem and a SSB QSO (where both uses are fairly clean). Do the same thing for two SSB QSOs.
    Here's what you'll find:
    1. Digital signals with error correction will sync and be usable in less bandwidth than voice.
    2. The Digital results under #1 will be less than acceptale due to the time and number of re-trys (my example of a Pactor modem taking 240 seconds to transmit a short message). What is "acceptable" is subjective, but if you re-wrote the modem's specs to the level of performance under #1 above, almost nobody would buy it.
    3. While digital modems may sync and work at levels below the noise floor (CW can do this as well with SSCW), they cannot exibit this low noise operation in the presense of a strong interfereing signal. They can do #1 or #3 but not both.
    I won't draw any voice conclusions. I'll let you do that for shux and grins.
  6. N5RFX
    Charlie,
    Is it only ARQ modes like PACTOR III that you are interested in testing?
    Mark N5RFX
  7. KY5U
    No sir, not hooked in. I am speaking of modes that would occupy the 3.5khz spectrum since that is where the robots will do the most harm to analog voice. I believe Pactor is important because that is what we'll see with Winlink. SCAMP too should be tested at some point.
    I am suprised we have not had a "byte-off" whereby we tableize the performance of all of these under various conditions in QST or CQ (and Newsline). The goal would be to prove or de-bunk the hype. What is the advertized performance? What is the performance under interference condx. How much interference can they take? How do they relate to SSB Analog Voice? What happens to through-put? Comparative occupance rate? Duty cycle?
    Oh well...
  8. N5RFX
    Charlie,
    I am not sure what you mean by "not hooked in", but you are looking for testing of any mode greater than 500 Hz necessary bandwidth? I think I understand. So let me go back to your 3 points so I can understand.
    "1. Digital signals with error correction will sync and be usable in less bandwidth than voice."
    When you use the term bandwidth, you are referring to throughput? If so, then you want to know when a particular mode's throughput decreases. What did you think the the MT63 tests that I posted? It showed that their is a 2dB capture effect. To continue testing with that mode you would like to have no copy from each transmissions (signals within 2 dB of each other) then move one of the signals away and see when both start to give 100% copy? There really is no throughput test with MT63 as thoughput is fixed based on the bandwidth and the interleaving that is used, so we would have to use a character error rate. Am I on track here?
    "2. The Digital results under #1 will be less than acceptale due to the time and number of re-trys (my example of a Pactor modem taking 240 seconds to transmit a short message). What is "acceptable" is subjective, but if you re-wrote the modem's specs to the level of performance under #1 above, almost nobody would buy it."
    I think this only applies to an ARQ mode? Correct me if I am wrong.
    "3. While digital modems may sync and work at levels below the noise floor (CW can do this as well with SSCW), they cannot exibit this low noise operation in the presense of a strong interfereing signal. They can do #1 or #3 but not both."
    I am not sure what I am supposed to test here. Can you explain in a different way? BTW I did not understand the noise floor arguments earlier in the thread, so maybe I am hopeless with this one.
    I don't want to waste my time testing things you and others are not interested in, so that is why I am asking a lot of questions. I would like to know what it would take to convince folks that mixing analog and digital signals is not as horrible as some are describing.
    Mark N5RFX
  9. WA0LYK
    WA0LYK Ham Member QRZ Page
    Your audio files are too big for me to download with a dial up line so I haven't listened to them.
    However, I really do doubt that SSB and digital can share a frequency without some adverse effects. I am sure net operations could be handled on top of a digital signal or other short term conversations. But routine SSB QSO's WILL SUFFER.
    I know how tiring and frustrating a hetrodyne can be when you try to ragchew over one. This happens even if the hetrodyne is several S-units lower. Lots of people don't experience this anymore because of DSP and auto-notch, but for those without this we hear it all the time.
    A digital signal in the background wouldn't be any different, except auto-notches won't work so a lot of people will hear the effects. The result is that the digital operators will not be affected and will continue, however, SSB QSO's will have to be cut short.
    In the long term this could result in fewer and fewer hams using SSB and quite possibly a lot of them dropping out of the ARS altogether. Now this may sound good to the digital elitist's who think we should be going all digital and removing the analog modes from the air, but be careful of unintended results. I can think of several, none of them good.
    The Region 1 representatives have decided that analog and digital should not be mixed on HF. They already have experience with this. While your tests may show it is POSSIBLE to mix them, ask yourself why another region with experience would recommend against it.
    I suspect they have already analyzed the adverse effects it could have on ham radio's viability in the long term. Remember, SSB drives the market today and most likely for at least another 10 - 20 years. SSB also controls the viability of several amateur radio manufacturers offerings. Doing anything that upsets the status quo and results in an early reduction of SSB operators could reduce the number of hams and equipment offerings.
    Jim
    WA0LYK
  10. N5RFX
    Jim,
    Thanks for the comments. I agree that it is not desirable to have a digital signal in the background, but why would this undesirable condition increase because we allow digital data content where we now allow digital image and voice content? I agree that if automatic control is not regulated, then there is a possibility that digital data emissions would increase in the phone bands; no argument there.
    I keep hearing about the region 1 representatives having decided that analog and digital should not be mixed on HF, but I have not found any papers that discuss the reasoning and the empirical data that shows mixing of analog and digital signals is problematic. Maybe someone can point me to the study that caused this action? The 2006 Region 1 bandplan certainly does not reflect a prohibition of mixing analog and digital modes.
    The fact remains that digital and analog signals share spectrum on HF today. Where is the documentation that shows that this is problematic?
    Mark N5RFX
  11. AB0WR
    A peak to average ratio of 0db indicates the peak and the average are the same value.
    ie. 20log (1) = 0db
    This isn't possible for a sine wave. That's what you would get for a square wave.
    Are you sure the program is analyzing the waveform correctly?
    I don't think you can just convert from peak/average to crest factor by adding 3db.
    For a sine wave with a peak voltage of 1v, the rms value is .707v. That makes the crest factor 1/.707 = 1.414.
    To change this to db you would use 20log(1.414) = 3db.
    The difference is 1.586 not 3.
    A good description of crest factor can be found at http://www.tinaja.com/glib/muse125.pdf. This is how I learned it anyway. Don Lancaster has always been a favorite author of mine.
    One thing everyone needs to be careful about is that although the term "average power" is bandied about a lot *I* always consider it to be "rms" average power unless otherwise specified. Your Mileage May Vary (YMMV).
    I'm surprised that your program doesn't analyze a straight sine wave right but shows the right figure for a two-tone test.
    The big problem with doing this at baseband is that the receiver impacts are not measured at all. My primary concern would be impacts of AGC on actual received signals.
    I'm going to have to think about this one some. I'm not sure I see any way besides doing this at RF. It would certainly be possible to do without violating FCC rules. You just need to work the transmitters at low power into a combiner or into a couple of dummy loads. The individual average power levels could be adjusted just using the S-meter on the receiver (if you trust the agc to be linear). But you will need two transmitters and a receiver to do the test. I'll have to see if I can come up with what is needed.
    tim ab0wr
  12. AE4TM
    AE4TM Ham Member QRZ Page
    Charlie, I'm listening from near your Florida address. Let your CW neighbors know you are not a 20wpm extra.
    Ed AE4TM
  13. AB0WR
    Mark,
    Here are the recommendations approved by the Region 1 plenary that addresses this.
    DV05_C4_Rec_13 It is recommended that the following proposed principles for new IARU Region 1 HF bandplans be accepted, and that the principles be included in the IARU Region 1 HF Manager's Handbook:
    CW operation is accepted across all bands, except within beacon segments.
    Telephony (including AM) is limited to certain telephony segments.
    Digital data modes are limited to certain digital segments.
    Digitised speech is considered a digital data mode regarding bandplan matters.
    The current IARU Region 1 band plan is well known and receives a high degree of respect and adherence within the IARU Region 1; hence major changes to the bandplan are not necessary for the time being.
    Proposed by SARL, seconded by RAAG, approved with 4 abstentions
    DV05_C4_Rec_14 That the bandplan created by the Bandplan Working Group be approved. (See Annex to recommendation DV05_C4_Rec_14)
    Proposed by DARC, seconded by OeVSV, approved with 5 abstentions
    A discussion took place on the changes that had been made, and whether they reflected the agreed bandplan principles in DV05_C4_Rec_13. Iceland pointed out that paper DV05_C4_13 was not totally consistent with paper DV05_C4_11. However it was agreed that the bandplan should be considered as proposed.
    It is obvious that they know that the bandplan doesn't match with the recommendations to keep digimodes separated from analog.
    It looks like that will be addressed in the future.
    If I can find any discussions of the issues that I havn't already posted, I'll put them on here.
    tim ab0wr
  14. N5RFX
    Tim,
    Look at your math.
    "For a sine wave with a peak voltage of 1v, the rms value is .707v. That makes the crest factor 1/.707 = 1.414."
    "To change this to db you would use 20log(1.414) = 3db."
    100% correct; but, why do you subtract 1.414 from 3? You need to be subtracting dB's from dB's.
    I think our problem is terminology. When I use the term peak to average power ratio, I am actually saying peak average power to average power ratio. Just like when you say Peak Envelope Power you are really saying peak envelope average power. Now I think the math will work. Using your Sine wave with a peak voltage of 1V and an RMS value of .707, the average power is .707^2 or .5 . Since the envelope is flat, the peak average power is also .5. So 10log(.5/.5) is 0dB. 3-0=3 so to convert from peak average power to average power ratio, add 3dB. Cool Edit pro gives me a peak average power and an average power in dB. I simply subtract the peak average power from the average power. Does that make sense?
    Mark N5RFX
  15. N5RFX
    Tim,
    Thanks. I have been looking to for information as to how they have come to the conclusion that digital and analog signals should not be mixed. Actually I am looking for any technical paper that discusses this subject.
    Mark N5RFX
ad: HamHats-1
