ad: Schulman-1
APRS with a Baofeng, Bluetooth TNC by Mobilinkd
Discussion in 'Amateur Radio News' started by KJ4YZI, May 22, 2017.
  1. KJ4YZI
    KJ4YZI Ham Member QRZ Page
    If you say APRS is not popular or useful, You are wrong. And the preppers know it. This video shows the Mobilinkd battery powered bluetooth TNC and a $26 HT can get you on the network, show other stations on a map and message to cellphones/email. Check it out..
      File size:
      159.1 KB
      661
    K9EZ, KM6GUA and K4LIX like this.
  2. N5ZKK
    N5ZKK Ham Member QRZ Page
    Previously I ran around the country with a Kantronics KAMplus and 30W on VHF and HF for APRS. This in the 90's through 2004.
    I have this Mobilinkd setup with the UV5R but into a mobile 5/8 wave antenna. After 5 weeks running this every day I must say this works much better than I expected for 4W.
    The battery life on the TNC outlasts the radio and the smartphone. I tried to run down the battery but gave up after two days. The only down point is the receive. Receive is not great but it doesn't double with other stations either so it can hear.
    https://aprs.fi/?c=raw&call=N5ZKK-14
  3. K3RLD
    K3RLD Ham Member QRZ Page
    forget the mobilinkd - for $20 you can get the baofeng interface cable that will connect directly to the phone for flawless performance. One less piece of hardware, one less battery to keep charged.
    K3TEF, SQ2MO, K9EZ and 1 other person like this.
  4. N8FF
    N8FF Ham Member QRZ Page
    it would be nice to get the "cookbook" version instead of the loooonnng video
    N7MK/SK2024 likes this.
  5. KA2CZU
    KA2CZU XML Subscriber QRZ Page
    the mobilinkd keys the transmitter vs. using vox that a direct cable would need.
    unless you know of software on the phone that will key the transmitter via the cable?
    just found better performance using the mobilinkd vs a cable in my own testing, but YMMV (and MMMBS... My Mileage May Be Suffering :D :D )
  6. K3RLD
    I've had 100% reliability using the VOX interface.
  7. KE5EUA
    KE5EUA Platinum Subscriber Platinum Subscriber QRZ Page
  8. KE7DUX
    KE7DUX Ham Member QRZ Page
    Thanks for sharing.
    1. I have concluded that the use of this will require an android device to be connected whenever used. This is "useless" by itself?
    2. If this does require an always-connected android device, can that android device be disconnected from the internet?
    That said, what is the benefit to this for $105 ($80 for Mobilink and Cable + $25 UV5R) versus something like the AP510 for the same price?
  9. KJ4YZI
    AP510 is 1 watt... And cannot be used for voice. This can be unplugged, and you radio returns to a dual band unit.
  10. KE7DUX
    Understood. However the radio (UV5R) will be used only for this use as I have other radios and have no need for another HT at the moment. So, it will not be used for anything else in my situation.
    So if the only benefit is flexibility to use in a few different ways, with different radios (which is a good benefit in most cases!) In my case I would imagine the AP150 would suit my dedicated needs better? (Dedicated APRS transceiver that will sit in a trunk, and does not need a phone).
    I should have mentioned - regardless of the solution, I will be using a small HT Amplifier that can convert 1-4w to 20-30w.
  11. VA3TWT
    VA3TWT Ham Member QRZ Page
    Do you have a link to the interface cable you mention?
  12. WE5Q
    WE5Q XML Subscriber QRZ Page
  13. KE7DUX
    KF0G likes this.
  14. N8DAH
    N8DAH XML Subscriber QRZ Page
    Nice to see its not 3d printed anymore.
  15. KJ4RZZ
    KJ4RZZ Ham Member QRZ Page
    APRS Seems like a lot of qrm just to say you are listening.
