A NEW FT8 with QSO and Rag Chew capabilities called FT8CALL
Discussion in 'Amateur Radio News' started by NN2X, Aug 12, 2018.
  1. NO2Y
    NO2Y Ham Member QRZ Page
    If you can have QSOS with the other modes, the -24db becomes academic.... especially if you use a narrow filter to decode the other modes. Then, there may not be a whole lot of difference between -24db in 2.5 KHZ and -10db in 100 Hz
    N0AN and K2NCC like this.
  2. NN2X
    NN2X XML Subscriber QRZ Page
    I love Olivia actually, especially the 500/8 flavor, which works at 30 wpm, the issue is -13dB is its threshold to decode, and it seems another 11 dB advantage does the trick for DX.
    Truth be told, I rather be on 10 meters SSB, when the band conditions were great, we just don't have that today...
    Cheers, NN2X, Tom
    WD4IGX and K8XG like this.
  3. NO2Y
    That's what I'm saying. Center on that signal. Narrow the filters so you cut out everything but that signal. There's your 10db
  4. NN2X
    Just to be clear, to obtain the -13dB, decoding threshold for Olivia 500/8, the Ham operator has to adjust the filters on his / her transceiver to be close at 500HZ, otherwise you will not obtain -13db threshold. For example if the filters are lets say 2.4Khz, you will loose the ability to decode at -13db below the noise floor. (For this example)
    This goes for any mode to be honest, less noise (Bandwidth) the better, but it can not be smaller the modulated carrier.
  5. NO2Y
    Not saying you're wrong, but you might want to check that. That would make it WORSE than PSK31. At least the numbers I've seen show PSK31 to be at -10db with a 2.5KHz bandwidth and show Olivia to be -13
  6. K8XG
    K8XG Ham Member QRZ Page
    I use all those and have PSK31, Olivia, FSQ and Contestia QSOs...But as the bands die down FT8Call I see as a really good tool in the tool box for QSO-Messaging-Checking Bands
  7. NN2X
    Yep!
  8. NN2X
    I do Link budgets all day long, that is a given, less noise, works all the time for advantage. dB = 10Log (Power out / Power in) this also applies the for bandwidth. But this is not the forum to work these formulas! Cheers, NN2X, Tom
  9. N2NH
    N2NH Ham Member QRZ Page
    FT8CALL! I was looking and searching for this in the wrong forum!
    An FT8 with ragchew?? I'll be telling me grandchildren!;):D
    Honestly, I didn't think it was possible.
    VA3OSO likes this.
  10. WH6FQE
    WH6FQE Ham Member QRZ Page
    Well, for those of us who are having trouble making a QSO with the available modes because of the lousy propagation and antenna issues, Yes, it is essential that a new more effective mode is available. Especially right now, I feel MUCH better knowing that FT8CALL is now available as I stare into the face of a hurricane that is going to hit us here in Hawaii in a couple days.
    N2NH likes this.
  11. LB9YH
    LB9YH Ham Member QRZ Page
    Hi Michael,
    FT8 uses the Olivia frequencies, and is creeping slowly lower, with the hound-feature. What do you think of FT8 using these frequencies?
    Kenneth LB9YH
  12. NO2Y
    Fox and hound is a very temporary thing. I took part in it during the Baker Island DXpedition. Not only is it temporary, there doesn't appear to be any frequency or range of frequencies whatsoever.
    As far as FT8 and Olivia, they're no longer the Olivia frequencies. FT8 took them. It caused huge damage to another mode....which was created in 2003 itself. It wasn't old and outdated as some seem to think PSK31 and RTTY are. But, taking these frequencies happened before my time in ham radio. When I got in, I started out on FT8. It was my first mode.
  13. N2IPH/SK2022
    N2IPH/SK2022 Ham Member QRZ Page
    Yes, it is. From my brain to the keyboard I got what I wanted to say turned around 180.
    I meant to say why not convert FT8CALL QSOs to FT8 and not to DATA.
    DATA being any digital mode like AX.25 packet, PSK31, etc.
    WH6FQE likes this.
  14. G3NYY
    G3NYY Ham Member QRZ Page
    Ah, yes. Well, at first I did log my FT8CALL contacts as FT8, but there have been a lot of postings in this and other forums from people saying that FT8 and FT8CALL are two distinct modes, and that it is incorrect to claim FT8CALL QSOs as FT8. So I went with the flow and logged them as data, until such time as the FT8CALL mode is included in the ADIF specs.
    Walt (G3NYY)
  15. KN4CRD
    KN4CRD Ham Member QRZ Page
    Yep. Preferred to log as data until we petition to be included in the ADIF tables.
    Version 0.5 will have an option to log from FT8Call as DATA too so you don't have to run a conversion or configure your logging software to map from FT8CALL to DATA.
    N2IPH/SK2022 likes this.
ad: portazero-1
