ad: CQMM-1
10 Meter beacon operators requested
Discussion in 'Contests, DXpeditions, QSO Parties, Special Events' started by KP3FT, Jan 8, 2008.
  1. KP3FT
    KP3FT Ham Member QRZ Page
    There are several states and countries in IARU Region 2 that could use a 10 meter beacon (or beacons) for propagation indicators. Currently Arkansas, Wyoming, New Mexico, South Dakota, Mississippi, Delaware, and Vermont have no beacons (as far as we know). Are there any hams interested in setting up a simple 10 meter beacon, or know someone who would? Many people in the USA and worldwide operate 10 meter beacons and also listen for them, and many send in daily reports. It is very interesting and helpful to see where propagation is open by listening for these beacons. People are hearing beacons every day even at this bottom of the solar cycle. Most beacons only run from 1 watt to 10 watts and many are simply old 23-channel CB radios that have been converted to 10 meters, with an inexpensive keyer connected. The keyers can be found for around $15. There are many places in Region 2 which do not have a beacon, and it would be good to see these areas with a 10 meter propagation indicator. Again, if you would like to operate one, or know someone who would, please contact Bill Hays WJ5O at wj5o "at" troycable.net . Mr. Hays is the IARU Region 2 HF Beacon Coordinator.
    For a map of USA and World 10-meter beacons, please see the following site:
    http://userpages.troycable.net/~wj5o/YourBCN.htm
    Here's a link to general information about 10 meters and simple 10 meter beacon projects:
    The following is a good article called "Exploring the World of Ten Meter Beacons" that recently appeared in The Monitoring Times:
    http://monitoringtimes.com/MT-10meters.pdf
    These are links to lists of the known 10 meter beacons worldwide:
    http://www.mydarc.de/dl8wx/baken_kw.htm
    http://userpages.troycable.net/~wj5o/bcn.htm
    This is a link to a 10 meter beacon-spotter website and other information:
    http://10mbeacons.com/beaconspot/spot90.php
    There is also a beacon spotter email reflector with daily logs here:
    http://www.explore.force9.co.uk/beacons/hfbeacons.htm
    It would be very good to see some beacons in blank areas. There are many places in Central America, the Caribbean, and South America that need beacons: Guatemala, El Salvador, Costa Rica, Nicaragua, Honduras, Belize, Jamaica, Cuba, Dominican Repuclic, Haiti, Chile, Bolivia, Ecuador, Columbia, Uruguay, Suriname, Falkland Islands, and the Galapagos Islands. We have received responses from a few of these countries already.
    Thanks and 73!
    Jeff KP3FT (KP3FT/B 28.222.5 Mhz)
    Ponce, Puerto Rico
  2. AD5KO
    AD5KO Ham Member QRZ Page
    My 10m Beacon is on 28.2600Mhz. Power is 12 watts. QTH is Mena Arkansas.
    AD5KO
  3. W4INF
    W4INF Ham Member QRZ Page
  4. KP3FT
    Hi Andrew,
    There's nothing wrong with it; it's another part of the beacon world and I hope it continues. I monitor it here sometimes and plan on setting up for transmitting sometime in the future. My post was mainly for the regular CW beacons that don't require any sort of decoding equipment, but there's no reason to exclude PropNet. The more the merrier...
    73 Jeff KP3FT
  5. K5OP
    K5OP Ham Member QRZ Page
    I'm in Mississippi and very interested in establishing a 10 meter beacon here. I also just happen to have an old Royce 23 channel analog CB radio sitting in the closet. I haven't turned it on in over 15 years but the last time I used it, it worked. I may learn how to modify it, get an automatic keyer and build a simple vertical and stick it in a pine tree in the back yard, and put the beacon in the shed. I emailed Bill some questions, perhaps he'll be able to give me some help.
  6. KA5ALO
    KA5ALO Ham Member QRZ Page
    ARKANSAS NOW HAS A 10 METER BEACON AT 28.260 MHZ.
  7. AD5KO
    How did it sound, what sort of signal are you getting?
    You can post beacon reports here:
    Beacon Reports
    Andrew
    AD5KO
    28.260
ad: wmr-1
