MFJ-1708SDR review - Share your antenna between your transceiver and an SDR
Discussion in 'Amateur Radio News' started by VA2PV, Jan 21, 2018.
  1. KG2C
    KG2C XML Subscriber QRZ Page
    Thank you so much for the detailed description and options on how to connect an amp. Looking at the diagram for the AL-80B, it looks like I will need to put a diode in line before the Relay connection.
  2. KA9JLM
    You should not need a diode on the amp, Because the MFJ-1708SDR has one.
    But it would not hurt anything to add one, If you can live with the 1 diode voltage drop.
  3. KM6CND
    KM6CND Ham Member QRZ Page
    Nice item. I brought home an SDRplay on Sat and was greatly disturbed by the warning that having the SDR too close to your TX antenna will blow up the unit and void the warranty. Naturally they didn't bother to define what "too close" is. o_O
    I am operating a 40M dipole or a vertical long wire and 100 watts on the side of the house. The SDR / Discone is in the back of the house, about 20 feet from one of the 40 meter wires. So far I have yet to blow it up...
  4. W0VRA
    W0VRA Ham Member QRZ Page
    I've got an SDRplay as well. I unplug the antenna from it and it picks up my TX on the QRP rig. Delay is <1s. Not blown up yet.
    I plan to use one of these eventually, built into the transceiver box.
    http://www.qrpkits.com/ezseries.html#eztrsw
    There will be an extra BNC on the back of the box that will go to the SDR. I've got the cheapo RTL-SDR Blog dongle that I don't mind putting at risk for shaking down the concept.
  5. KM6CND
    Just picked up mine yesterday. It has a plastic case (everything else I have from MFJ is metal) and works as intended.
  6. N2AMG
    N2AMG Ham Member QRZ Page
    I must be brain dead today as this is just passing over my head.. I have a 706MK2g and I'm trying to figure out where I am tying the PTT plug to. I have the RCA plug wired at about 3
    long as to where the radio sits from the antenna and I am drawing a blank as to what pins I am tying this to? Do I go from ground to the Hsend/PTT pin #3 on the back connector or where am I tying it to??
  7. VU3RCN
    VU3RCN Ham Member QRZ Page
    Good video. It is a good stuff from MFJ solving all waterfall issues where some of the modern transceivers do not have an IF output.
  8. KA9JLM
    You would connect it to the same connection that would be used for keying a amplifier.
  9. N2AMG
    Thanks..
    Need to find my manual now..
    73 Rick
ad: Retevis-1
