ad: Schulman-1
New Antenna Theory
Discussion in 'General Announcements' started by HB9ABX, Jul 6, 2014.
  1. HB9ABX
    HB9ABX Ham Member QRZ Page
    Theory of Roomcap
    This a major additional part to the classic theory!
    Since a longtime many were waiting for the theory for this antenna.
    Now, the theory is good description with pictures and explanations,
    and the difference between the classic wire antenna and the "New
    HF Antenna". - In a few words:
    classic = current in wire
    new = current over planes
    Description of H-field / E-field, what is important different of the
    Maxwell's equations in the treating, down to the virtual photons
    what different for "current in wire".
    And what happend with the near-field.
    Also important:
    The RBN analyse of the signal signal strength throughout Europa wide.
    Both publications appeared in the last days.
    Use this link to read all details:
    http://hb9abx.no-ip.biz/ant21jun14e.htm
    http://hb9abx.no-ip.biz/ant23jun14e.htm
    In the second text you see the comparisons between Roomcap
    and wire antennas.. This comparisons I made these comparisons
    during many years. However, many people did not believe to
    the indicated reports, because the measurements were done in
    SSB and with manual reading.
    Therefore, in the last months I performed many tests in RBN in
    mode CW.
    The transmission was performed automatically, and the measuring
    of the signal reception and analyse done automatically.
    In each test more than 25 RBN stations sent their reports from
    distance between 140 km to 2500 km.
    What results ? It is worth to see this!
    > To be astonished !!!
    Best 73s
    Felix HB9ABX
  2. AB1UP
    AB1UP Ham Member QRZ Page
    llinks return gateway timeout
    I clicked on the links in the article and received "HTTP ERROR: 504 Gateway timeout" on both links.
  3. IZ3NYT
    IZ3NYT Ham Member QRZ Page
    Hi Felix,
    I do not see much difference between your and a loaded monopole, it creates a very high voltage on the vertical section, but reception is very noisy, can I ask where is the difference?
    73 de andrea
    http://greenradio.altervista.org/
  4. KC8VWM
    KC8VWM Ham Member QRZ Page
    It would be helpful if there is a webpage with a working design model with actual construction details.
    Otherwise it continues to remain as a theoretical antenna.
  5. KA0HCP
    Felix has posted his money making scheme before in the Antenna Forum.
    Lots of gibberish, atrociously wrong electrical theory, all leading to links that require you to send him money in exchange for his 'secrets'.
    Don't waste your time.
  6. KF5FEI
    KF5FEI Ham Member QRZ Page
    ...But wait, order now...
    Yeah, kinda what I got out of it.
  7. IZ3NYT
    these formulas you create a monopole good yield, I do not know what theory refers Felix.'m curious.
    RA=resistance of antenna
    H=height in meters.
    L=inductor on the base
    C=Cv=capacitor virtual place radiator and ground
    X=Bandwidth
  8. IZ3NYT
  9. N2ADV
    N2ADV XML Subscriber QRZ Page
    Gotta admit: he's persistent...
