zerofive rotatable dipole
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KB4MNG, Jun 1, 2012.
  1. KB4MNG
    KB4MNG Ham Member QRZ Page
    I am looking at purchasing a 20 meter zerofive rotatable dipole. I was wondering if a rotatable dipole is much better than a fixed position wire dipole. Will I see a big difference in the received and transmitted signal? I would like to have a yagi but unable to do so. This will only be about 35 ft up.
    kb4mng
  2. K9STH
    K9STH Ham Member QRZ Page
    Being able to rotate the antenna is definitely better than a fixed one. Although the basic pattern is still a "figure 8", turning the antenna allows the other station to be "peaked" in whatever direction it is located. With a fixed dipole you generally have nulls over about half of the pattern.
  3. K3SI
    K3SI Ham Member QRZ Page
    Have you considered one of the multiband rotatable dipoles that are out there? Or you could look at the driven element of a beam, Mosley has two models that will cover 20,15,&20.
    73 Dave K3SI
  4. KO6WB
    That depends, sometimes the pattern of a dipole antenna isn't exactly the same as the ones shown in the books. The amount of null off the sides may only be a few db down or it could be quite a bit more. For a rotator all you need is one that will move the antenna 180 degrees. That will cover all the possible pattern peaks and nulls of a properly installed dipole.
    You could also make the antenna yourself from aluminum tubing and do well.
    Good luck on your installation.
    Gary
  5. NA7U
    NA7U Ham Member QRZ Page
    Will you be able to get a Yagi, quad, etc. sometime in the future? Seems like a lot of bread to layout for a dipole, even if it is rotatable, especially if you are going to replace it someday. You could get essentially the same effect by putting up two wire dipoles more or less at 90 degree angles as either flat-tops or inverted vees. Anyway, at least you've got a 1/2 wl. of height, which should help your DX TO angle a good deal.
  6. K8JD
    K8JD Ham Member QRZ Page
    If you can only get it up 35 ft it is a waste of money !
    On 20 M, a wire dipole at 35 ft will do the same thing and cost about 30 bucks if you buy the wire and insulators brand new.
  7. AE7F
    AE7F Ham Member QRZ Page
    Have you looked into buying/building a cobwebb antenna? Don't need to rotate it and it will work great on 5 bands.
