ZeroFive 43 ft. vertical experience?
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by AC2MM, Jan 1, 2018.
  1. K8JD
    K8JD Ham Member QRZ Page
    Transmorgified Antenna
    Take the "Magic" 43 ft vertical,
    Substitute #14 THHN wire for the aluminum pipe
    Double it
    Lay it on it's side
    get it up in the trees
    Feed it with 450 Ohm twinlead thru a MFJ974 balanced line tuner
    NOW you have my 20M EDZ but it works fine from 5-18 MHZ with that tuner !
    AK5B likes this.
  2. KB6HRT
    KB6HRT Ham Member QRZ Page
    Have one of Tom's Z5 43' vertical, now use it for 160m an it work very well, when I first installed the antenna back in 2009 I put down 3000 feet
    of NR 14 AWG THHN wire as a ground plane, Tom made me a coil that installed at the base, which hooked to the UNUN to give the antenna a little more lanth, using 150' of coax and a full range 10 to 1 tuner could work 160-20m the bands I was interested in working. Some time later Ron Dougless an I did a mod to the 43'vertical antenna, now I will call it a system, adding one of his Screwdriver antenna in series with the 43' vertical, this made the 43' a resident
    antenna system, this gave 2s units more signal on output but brought in more noise on the receiver of course, I then added a My Antennas CMC choke which helped the signal to noise ratio on receive, after a couple of years, called Tom an asked him what others were doing to improve there output on 160m , Tom said try adding 3 30 radiates 3' down from the top of vertical element of the antenna, this has worked quite well because the antenna system now has both a vertical and a horiszonal component which deals with fading issues on transmit and receive quite well I use this antenna system 4 to 5 times a week with very good results where I rag chew on 160m YEAR around...Tom has giving me information freely an help me a great deal and in I my book is a great guy...................kb6hrt
  3. K8JD
    I did not have to waste a lot of $$$ on radial wire.
  4. N0YPD
    N0YPD Premium Subscriber QRZ Page
    You missed out on all the fun..
ad: UR5CDX-1
