Zero-ohm Resistors
Discussion in 'Ham Radio Discussions' started by K4KYV, Mar 4, 2014.
  1. K8ERV
    K8ERV QRZ Member QRZ Page
    When you do find the -10 ohmmers, just put 10 in series.
    TOM K8ERV Montrose Colo
  2. W2JKT
    W2JKT Ham Member QRZ Page
    Yes, I do. They're nonlinear. An op-amp negative resistor is a whole lot more linear than a tunnel diode.
  3. W1GUH
    W1GUH Ham Member QRZ Page
    But they don't cause a mushroom cloud, at least, as far as we know?
    Here's a couple of tunnel diodes - the stoplights.
    We've got a few bridge diodes, too.
  4. KD3NE
    KD3NE Ham Member QRZ Page
    BINGO !!!!
    I have then in surface mount packages and that is exactly their purpose. ( jumpers )
    Makes for a nice clean board design.
    Also I believe that Motorola uses them as "fuses" in their Maxrac Radios, but not in a surface mount package.
    They look like a regular resistor except they are colored/marked differently.
    If you get a Maxtrac that will not power on unless you apply 12 VDC to the " ignition sense " line, that zero ohm resistor is blown. ( in most cases )
  5. K8ERV
    Not gonna touch that one!
  6. WJ4U
    WJ4U Subscriber QRZ Page
    0 ohm = path to least resistance
  7. WA7DU
    WA7DU Ham Member QRZ Page
    What would be the tolerance range for a zero-Ohm resistor?
  8. WJ4U
    Plus or Minus zero
  9. K8ERV
    That's a pretty tight tolerance.
    I would buy +- 10%. (Let's see how many get that one).
  10. WA7DU
    I'm feeling very liberal today--I say we should allow plus or minus 100 percent. What could it hurt?
    Now for something really exciting...
    Referring to the discussion above, the value of R is given; assume an unknown value of I through the resistor; let us say you have a volt meter of infinite input impedance and wires in the ideal state. You measure the voltage drop across the resistor. What is the power dissipated in the resistor? Show your arithmetic, including the "law" used, and each step of the calculations. Or, state the enigma.
