ad: w5yi
YP3 antenna
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KF5DMC, Jan 15, 2011.
  1. KF5DMC
    KF5DMC Ham Member QRZ Page
    need to know if any one has the YP3 Tri Element Sixband antenna.. or not. I need to get a replacement Coax connector that my coax plugs into the antenna. This antenna is from the SuperAntennas Company out of Lincoln, Ca which apparently no longer exist at all. Ive called/email them and nothing works and i need a replacement coax plug in so I can continue to use my YP3 Yagi..
    KF5DMC
    kf5dmc@yahoo.com
  2. G0GQK
    G0GQK Ham Member QRZ Page
    If the company is no longer in business you won't be able to buy the part you need and if there are people using this antenna there will be little chance of them removing their coax connector. Would it be possible for you to devise a different way of attaching the coax to the antenna with a standard coax connector readily available ?
    G0GQK
