Your thoughts: Clip-on attachment to make 40m vert into 80m
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KE0EYJ, Jan 18, 2020.
  1. AJ5J
    AJ5J Ham Member QRZ Page
    Statements like this really tarnish your cool reputation, Iceman.
    ---Copperman, shaking his head...
  2. KH6AQ
    KH6AQ Ham Member QRZ Page
    How much wire to add
    Ideally ~65' of wire would be added to one end of the 40 meter dipole to make it a resonant OCF 80 meter dipole. If that's too long to fit I'd add 35' to make it a 100' OCF dipole.
    Unbalance
    What is the antenna tuner model number? Some tuners have CM chokes on the output and others have voltage baluns. The latter drive one side of the balanced output directly off the tuner LC components with other balanced output connected to a transformer that flips the polarity. You might have less RF-in-the-shack issues with a CM choke between the ladder line and the tuner.
    KE0EYJ likes this.
  3. KE0EYJ
    KE0EYJ Ham Member QRZ Page
    Ancient MFJ-962 Versa Tuner III first release.
  4. WA9UAA
    WA9UAA Ham Member QRZ Page
    EYJ,
    Make the vertical a tilt over so you can add wire to both sides of the antenna. Adding wire to one side will give you an Off Center Fed antenna but will result in unbalanced feed line and beaucoup RFI. Another option might be to end load both parts of the antenna so it will load up on 80M.
    Rob
ad: Alphaant-1
