Yet another HRD not uploading to LOTW...this one has me stumped!
Discussion in 'Ham Radio Deluxe - HRD' started by W6NFL, Aug 29, 2014.
  1. KB1NXE
    KB1NXE Ham Member QRZ Page
    Since using the new Unicode and libraries, a whole lot better with Win 8. But then again, I should say as well as anything works with Win 8... :)
  2. KA9JLM
    I hear you.
    The best solution for a Win8 machine is Linux. Many of them will not let you roll back to Win7.
  3. W6NFL
    W6NFL Ham Member QRZ Page
    I downloaded 6 and it fixed the issue. Thnx for advice.
  4. KB1NXE
    You do realize that's only good for 30 days unless you purchase it? Just want to make sure you know what you are getting into...
  5. K0MB
    K0MB Ham Member QRZ Page
    I seem to be having the same, or very similar problem. Starting yesterday, HRD could no longer sucessfully upload QSO data to LoTW. The Logfile report was very similar or the same as that shown by the first user. I then went from vrs 6.2.4.280 to 6.6.72, and tried again. As the other user reported, when I uploaded an HRD log entry to LoTW, the "Finished" notation never came up. Closing that box, however, the HRD log file column for LoTW Uploaded changed to "Yes." A quick visit some time later to LoTW revealed that the new QSOs were, in fact, not loaded to LoTW.
    Computer is an older Pent 4 Windows machine running XP.
    Here is my LogFile report:
    20:13:31 LOTW Login Error = A connection with the server could not be established
    20:13:31 GetHttpConnection Failure ........: Login
    20:13:36 LOTW Creating C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.ADI...
    20:13:36 LOTW Exported 5 entries to C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.ADI
    20:13:36 LOTW Signing ..: C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.ADI
    Command ..: "C:\Program Files\TrustedQSL\tqsl.exe" -a all -d -l "home" -p "k0mb" "C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.ADI" -o "C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.TQ8" -x
    20:13:36 Signing Command = "C:\Program Files\TrustedQSL\tqsl.exe" -a all -d -l "home" -p "k0mb" "C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.ADI" -o "C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.TQ8" -x
    Error = TQSL Version 2.0.3 [v2.0.3]
    Error = Signing using Callsign K0MB, DXCC Entity UNITED STATES OF AMERICA
    Error =
    Error = C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.ADI: wrote 5 records to C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.TQ8
    Error = C:\DOCUME~1\COMPAQ~1.HAM\LOCALS~1\Temp\LOTWUpload 2014-10-17 201314.TQ8 is ready to be emailed or uploaded.
    Error = Note: TQSL assumes that this file will be uploaded to LoTW.
    Error = Resubmitting these QSOs will cause them to be reported as duplicates.
    Error = Final Status: Success (0)
    Error =
    20:13:39 GetHttpConnection URL ............: lotw.arrl.org
    Internet port ..: 443
    20:13:39 CHttpConnection::OpenRequest Verb ..........: 0
    Object name ...: /lotwuser/default
    Referer .......: https://lotw.arrl.org/lotwuser/default
    Accept types ..: NULL
    Version .......: NULL
    Flags .........: 04803000
    20:13:40 LOTW Login Error = A connection with the server could not be established
    20:13:40 GetHttpConnection Failure ........: Login
    20:13:46 Reload Loaded 2516/2516 records in 1609 milliseconds, 1563.7 records per second.
  6. AA6YQ
    AA6YQ XML Subscriber QRZ Page
    Open Internet Explorer's Tools menu and select the "Internet Options" command. In the "Internet Options" window, select the Advanced tab, and scroll down to the Security settings. Enable the "Use TLS 1.0", "Use TLS 1.1", and "Use TLS 1.2" options (not all may be present on IE versions earlier than 11). Click the OK button. Can you now upload to LoTW?
    Dave, AA6YQ
  7. K0MB
    AA6YQ, I don't know if your comment was for me, but I did as you advised. I found only "TLS 1.0", which I enabled. Then I reloaded HRD, and submitted log entries again. I did get the "Finished" notation from HRD, but going over to LoTW's home page and opening my QSO file, they are not there. I allowd 10 min for the update, and saw that ARRL was not reporting anything special about a que of logs that might mean an unusual lag time for updates.
    K0MB
  8. AA6YQ
    Yes, K0MB, my comment was for you (and anyone else experiencing similar symptoms).
    45 minutes ago, the LoTW Queue length was 7 minutes, and could have increased since then.
    If you didn't previously have TLS enabled, and if you no longer see the errors you posted above after enabling it, then likely that was the issue.
    Dave, AA6YQ
  9. K0MB
    Thank you, AA6YQ! Although I don't understand what had changed to cause my problem, or what the heck TLS is, but enabling it seems to have been the solution. LoTW was apparently backed up, and the new uploads are showing now. Here's hoping it stays that way!!
    K0MB
  10. KA9JLM
    Last I heard HRD will no longer be supporting the XP OS.
    I see that as a Bummer for us old school XP users.
    It sounds like a Browser auto update hosed you a bit. MS is killing XP slowly.
    Have Fun.
