YEASU FT857D CAT Control
Discussion in 'Amateur Radio Software' started by PY2MLS, Mar 1, 2014.
  1. PY2MLS
    PY2MLS Ham Member QRZ Page
    Hello friends,
    Sorry for my ignorance, but is there any way I can any control software with my FT857D without using the CAT port.
    The thing is that I have a Tuner plugged in, using the CAT rear connection.
    TKS
  2. KA9JLM
    Does your Tuner have a CAT thru port ?
    Good Luck on your project.
  3. PY2MLS
    nope, tuner on, no CAT available...
    only way is to use the radio without the tuner, and this out of question, since I use a multi-band antenna.. .
  4. KA9JLM
    Sounds like using the mic connection may be the best solution.
    http://www.k6xx.com/radio/ft857ser.pdf
    Good Luck.
  5. F1EPQ
    F1EPQ Ham Member QRZ Page
    Hi,
    as you know it, many renowned tuners such as the LDG-Z11Pro2 etc... use the FT-857/FT-897 ACC port via an Y-ACC cable very simple to make with only 2 stereo jacks.
    Unfortunatly in your case there is still a nice solution which is to use the front MIC jack in which the CAT functionality is replicated through the MENU 59 of your transceiver. It is a very smart and convenient solution and you have only to build a adapter (not too difficult with a little care) or to find it. And it works.
    Here are the links for the accurate explanation of the "CAT-MIC" solution :
    Word document :
    http://www.iz0inx.it/download/CAT-Mic.doc
    General mods infos :
    http://www.radioamatoripeligni.it/i6ibe/
    Good luck and Best Regards,
    Sorry for Don KA9JLM, I was writing my post at the same time !
    Jean-Luc - F1EPQ
