Yeasu ft221 vs ft221r-boards interchangable?
Discussion in 'VHF/UHF - 50Mhz and Beyond' started by N9AXL, Jul 24, 2016.
  1. N9AXL
    N9AXL Ham Member QRZ Page
    I have an ft221 and someone wants to give me parts ft221r. I'm happy to do this if the boards and others parts are interchangeable-otherwise this "gift" needs to go somewhere where it can be used. Limited storage space and too many other projects right now.
    Aside from the repeater split it seems they are the same radio. So wouldn't expect every board would be the same but the audio, finals, etc. should identical.
  2. W9GB
    Early 1980s multi-mode VHF (2-meter) transceiver.
    You likely could repair the FT-211R unless it has been abused, stripped of key parts.
    FoxTango International has the Yaesu Service Manual(s)
    http://www.foxtango.org/ft-library/FT-Library/Eighties/Eighties.htm
    Earl Andrews, VE3AB has FT-221 parts and
    noted that bad solder joints and crystal failure apprars to be common issue.
    http://www.earlandrews.com/FT221rig.html
    Yaesu FT-221R is model with Repeater Shift.
    Yaesu FT-221RD is model with Repeater Shift & Digital Display.
    Yaesu YC-221 external digital display works for both FT-221(R) models.
    http://www.earlandrews.com/files/YC-221_Manual_dd.pdf
    As noted by WA6MHZ, here on QRZ (who has a FT-221) ..
    http://forums.qrz.com/index.php?threads/yaesu-ft-221-mods-for-the-yc-221-display.336191/
    the FT-221R is almost plug-n-play --- while additional work is requured for the FT-221.
