brand new, straight out pf box. wired cable.. checked continuity..satisfied.. plugged in, pushed rotate moved a few degrees stopped!!! Won't move at all now.. Had 2 other hams verify my cable ends with vom, and manual. We tried to find maybe a loose plug connection. cable checks out 100% Any suggestions would be appreciated. tom
I had similar effect when I used a long (>100 ft) and thin cable. Check it with a short cable. If it works you will need to use a cable with thicker wires.
hums,, but won't rotate....bought a second one also brand new... does the same thing,. even with a 6 foot cable.. I'd say I've done something wrong... Have had several friends confirm my cable/plug wiring according to the manuals.. Need any and all pertinent suggestions.. tom
