Yaesu ft450d, signalink usb help needed
Discussion in 'Working Different Modes' started by M0TXP, Jan 12, 2013.
  1. WA6MHZ
    WA6MHZ Ham Member QRZ Page
    I had the same trouble with my SignalinkUSB and the FTdx5000. It turns out U need to turn the gain on the SLIDER CONTROLS in the computer all the way up to provide enough audio to get the radio to key. Then adjust the front panel TX Audio control for best TX Audio. Look for the Computer volume control and turn it up to maximum.
  2. M0TXP
    M0TXP Guest
    Thanks guys
    I done all that, the only way i could get the waterfall to work in dm780 was putting the mono cable in between the signalink and 450d
    were as you should not have to do that as it comes through the data cable
    When i put the mono cable in as described the radio speaker cuts out and the waterfall works and when i turn the volume up on the radio the receive goes up but i cant hear the audio, but when i use just the data cable i can hear the rx audio out the speaker on the 450d but no waterfall activity on dm780
    Done everything in the manual and no joy, i sent it back to the shop and they are going to investigate
    paddy
