ad: UR5CDX-1
Yaesu FT-9800R
Discussion in 'Mobile Radio Systems' started by G0AOZ, Aug 2, 2018.
  1. G0AOZ
    G0AOZ Ham Member QRZ Page
    I also own a TYT TH-9800 transceiver, which has a feature which does not appear to be available on the FT-9800.
    On the TYT TH-9800, a short press on the lefthand VOL/SQL button puts the transceiver into Single Receive mode, i.e. the righthand VFO is switched off. Can this same function be achieved on the FT-9800?
  2. K6CPO
    K6CPO Ham Member QRZ Page
    I'm not sure there ever was a Yaesu FT-9800. Are you sure you don't mean the FT-8900R? The TYT is a blatant ripoff of the FT-8900R.
  3. G0AOZ
    Sorry, yes, the Yaesu rig is an FT-8900R. I am, of course, aware that the TYT TH-8900 is a less than favourable copy of the FT-8900R, which is why I was surprised the Single Receive mode feature does not appear to be available on the Yaesu rig. Or perhaps someone knows otherwise...?
  4. K6CPO
    Well, if I can get the cat off my desk, I'll dig out my FT-8900 go-kit and see if it's possible to do that with it. Standby...
    I'm back... The Yaesu FT-8900R DOES NOT have that function in the left hand squelch/volume control. What is does is toggle the old WIRES internet linking system on and off. Since that system was proprietary to Yaesu, TYT decided to do something else with that function.
    I think being able to turn off one VFO could be a useful function.
  5. GW8LGX
    GW8LGX Ham Member QRZ Page
    You can turn one vfo off.
    Enter the SET mode, select DSP.SUB, then set to OFF, exit SET mode. Behold, one vfo.
    Hope this helps.
  6. G0AOZ
    GW8LGX, thank you. Worked a treat!
