SOLD YAESU FT-950 HF Transceiver, Never Used, Factory Updated
Discussion in 'Ham Radio Gear For Sale' started by K2XK, Dec 12, 2018.
Tags:
  1. K2XK
    K2XK Ham Member QRZ Page
    YAESU FT-950 HF transceiver - This radio was purchased by me brand new in 2010 and never used or even powered up. I sent it back to Yaesu USA for a Factory Firmware Update in 2012. It has always been stored in the original box in my smoke-free house. Factory mic. Priced at $800 firm (plus shipping). No International Shipping. Shipping costs are not included. Shipped via USPS Priority mail with insurance. Text me with your call sign or zip code for shipping quote. I may be able to deliver regionally or you can pick up FREE in Sheridan, New York 14135.
    Sorry, NO trades. You can text or call me directly @ 716-410-1949. Thanks! ...John K2XK​
    FT-950 Specifications
    GENERAL
    RX Frequency Range:
    30 kHz to 56 MHz
    TX Frequency Ranges:
    160 to 6 m (Amateur bands only)
    Frequency Stability:
    ±0.5 ppm (after 1 min. @ 25 °C)
    Operating Temperature Range:
    14 ° - 122° F (-10 °C ~ +50 °C)
    Emission Modes:
    LSB, USB, CW, F3E FM, F1B RTTY, F1D Packet, F2D Packet
    Frequency Steps:
    1/10 Hz for SSB/CW/AM
    0
    100 Hz for FM
    Antenna Impedance:
    50 ohms balanced, 16.7 to 150 Ohms, unbalanced (Tuner ON, TX only)
    Power Consumption:
    13 VDC
    RX (no signal)
    2.0A
    RX (signal)
    2.5A
    TX (100 W)
    22 A
    Supply Voltage:
    13.8 VDC
    Dimensions (WHD):
    14.4 x 4.5 x 12.4 inches
    Weight (approx.):
    28.7 lbs.
    0
    TRANSMITTER
    Power Output:
    Adjustable 5 to 100 watts (2-25 watts AM carrier),
    0
    50% @ 100 watts (FM & RTTY, 3-minute TX)
    Modulation Types:
    J3E (SSB) Balanced,
    A3E (AM) Low-level (early stage),
    F3E (FM) Variable reactance,
    Maximum FM Deviation:
    ±5.0 / ±2.5 kHz
    Harmonic Radiation:
    Better than -60 dB (Typical)
    SSB Carrier Suppression:
    At least 60 dB below peak output
    Undesired Sideband Suppression:
    Audio Response (SSB):
    Not more than -6 dB from 300 to 2700 Hz
    3rd-order IMD:
    - 31 dB 14 MHz @ 100 watts PEP
    Microphone Impedance:
    600 Ohms (200 to 10k ohms)
    0
    RECEIVER
    Circuit Type:
    Triple-conversion superheterodyne (VFO-A)
    Intermediate Frequencies:
    0
    VFO A:
    69.450 MHz/450 kHz/30 kHz [24kHz for AM/FM]
    Sensitivity:
    Modes
    0.5 - 1.8 MHz 1.8 - 30 MHz 50 - 54 MHz
    SSB (2.4 kHz)
    2 uV 0.2 uV 0.125 uV
    AM (6 kHz)
    6 uV 2 uV 1 uV
    FM
    - 0.5 uV (28-30 MHz) .35 uV
    (with RF2 amp on)
    Selectivity (-6/-60 dB):
    Modes Min. -6 dB BW Max. -60 dB
    SSB 2.4 kHz 3.6 kHz
    AM 6 kHz 15 kHz
    CW/RTTY/Packet 500 Hz 750 Hz
    FM 15 kHz 25 kHz
    IF Rejection (1.8 ~ 30 MHz):
    Image Rejection (1.8 ~ 30 MHz):
    70 dB or better (160-10m)
    Maximum Audio Output:
    2.5 W into 4 Ohms with <10 % THD
    Audio Output Impedance:
    4 to 8 Ohms
    Specifications are subject to change, in the interest of technical improvement, without notice or obligation.
    K5MTY, KC2YMO, VE7YE and 1 other person like this.
  2. K2XK
    SOLD - Thank you Bill!
  3. QRZ
    Important Rules
    Have you read our Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
