Yaesu FT-920 with Signalink and WSJT-X problems
Discussion in 'Working Different Modes' started by KD4VOJ, Jan 11, 2019.
  1. KD4VOJ
    KD4VOJ Ham Member QRZ Page
    I am trying to get my FT-920 setup with a Signalink USB and WSJT-X ver2.0 to run FT8. The Signalink is connected to the radio using the SL-CAB5PD DIN cable. I am having two issue I hope someone can help with. I have not changed any of the rig menu items. The PC is running Win10.
    1. I can decode FT8 traffic just fine with the radio mode set to USB, but if I set it to USB-DATA, I stop decoding traffic. I double checked to make sure the frequency was set properly after selecting the DATA mode. I saw on other post online about an OP with this problem, but never saw a solution for it.
    2. When I try to transmit FT8 traffic, nothing is getting transmitted. The rig keys up, but there are no tones. I listed to the Tx audio with the MONI function and there was no tones. I verified the soundcard selection on the PC was set to use the PC's Realtek soundcard for both playback and record, and verified the WSJT-X soundcard setting was also set to the PC's Realtek soundcard for both playback and receive per the instructions. The levels sliders on the PC soundcard are set to about midrange,
    Any advice on what I am missing in the setup, menu settings, or other things to check would really be appreciated
    Tnx,
    Rick
    KD4VOJ
  2. KE5MC
    For item 1. likely USB and decoding is set to upper sideband as it should. When switched to USB-DATA check that it is set to upper sideband too.
    For item 2. which I have trouble following which is on me, I don't see where you have used the Signalink as a selection for audio in either direction. Also no mention of addressing the jumper block inside the Signalink. Wishing I could be of more help.
  3. KD4VOJ
    Mike, tnx for the reply. The jumper block inside the Signalink is the pre-made one from Tigertronics.
    For the second issue description, the problem is there is no modulation (tones) when transmitting. The rig keys up, but its is just a silent carrier, no audio. Doesn't setting the Audio configuration in WSJT-X for both receive and transmit soundcards to PC's Audio Codec on the Enhanced and standard comm ports, per the Signalink instruction, essentially select the Signalink as the selection for audio in both directions?
  4. W5DXP
    W5DXP Ham Member QRZ Page
    Question: Why are there so many threads involving problems with expensive interface devices designed to solve interfacing problems?
    WB5YUZ likes this.
  5. KD4VOJ
    Found the problem. In the FT-920 menu U46 defaults to LSB and needs changed to USB for WSJTx, plus the FSK-AFSK switch on the back has to be on AFSK. Once that was fixed I could select USB-DATA that fixed everything. I found out the outgoing signal is only supplied to the DATA DIN port when you are in DATA mode, not in straight USB.
    WB5YUZ and 4X5ZS like this.
  6. KE5MC
    Good to see you solved the issues.
  7. KE5MC
    My opinion is that interfacing is a serial linking process. Each step has to be correct before going to the next step. The first mistake negates changes that follow creating confusion and frustration. Bring radios and computers together raises the need to understand how they interact with each other beyond the typical microphone/key device we have traditionally had.
    Mike
  8. W5DXP
    I prefer something to which I can attach an oscilloscope, e.g. external sound card dongle, EASYdigi board, USB/Serial dongle, etc.
    WB5YUZ likes this.
  9. VK6LIN
    VK6LIN Ham Member QRZ Page
    Great that you find the solution. Is the frequency offset (1170/1700/2125/2210) displayed annoying a bit as well? Any idea how to get rid of this offset or which is the right to choose while using FT8 please?
  10. 4X5ZS
    4X5ZS Ham Member QRZ Page
    Thanks for the lead to the U46 menu item!
    The frequency offset is not just annoying, it also prevents the radio from operating in the entire bandwidth allocated for FT8.
    To remove the offset, use menu U45 and set the offset to zero. After this change the received frequencies shown in the FT8 program are the same in USB and DATA-USB modes.
