Yaesu FT-891 separation cables & bracket: same as FT-857D?
Discussion in 'Mobile Radio Systems' started by K5VV, Sep 6, 2017.
  1. K5VV
    K5VV Ham Member QRZ Page
    The radios look very similar. Tuner & Data mini-DIN ports are similar per the manuals. Looks like the power cable connector is different.
    Any idea if the separation cables (control head & mic) and mounting bracket are the same?
  2. K0BG
    It is not remote controllable like the 857 is (separate head). It does have a ethernet port, and a remote key pad so some of the functions can use remoted. The software isn't out there yet, so no one really knows to what extent it is remotely controllable.
  3. K5VV
    I'm asking about the separation cables for use in a vehicle (10-15' between radio & head). Not remote over the Internet.
  4. K0BG
    According to their web site, and preliminary information on the transceiver, it does not have a removable head. You can download the manual from Yaesu's site.
  5. K5VV
    Are we talking about the same radio?
  6. ND6M
    ND6M Ham Member QRZ Page
    They are NOT the same.
    857d has TWO cables
    891 has three
  7. K5VV
    Hmm, I thought the 857D has three. Control head, microphone, speaker. I guess you could use two and plug the speaker into the headphone jack on the control head.
  8. K0BG
    You did say FT-891. The mobile bracket is a MMB-82, and I don't know if that is the same one or not. But the only remote for the FT-891 is a remote keypad. Here is the link for the manual. FT-891 Operating Manual
  9. WC5P
    WC5P Premium Subscriber QRZ Page
    FT-891 Brochure states that the front panel is detachable and lists the separation kit as YSK-891.
    I have no idea if it is the same as the 857 separation kit, but the kit model numbers are different for sure.
  10. N2PQW
    N2PQW Ham Member QRZ Page
    Matthew,
    It would appear to me, based on comparing the YSK-891 image from GigaParts.com
    to the YSK-857 image from Radio World (UK)
    the cabling appears to be the same, however the mounting nest for the control head seems to be different.
    For what it's worth, MMB-82 is the mounting bracket for the main unit.
    Also, from my experience, the neither the microphone extension cable, nor the Control Head extension cable are shielded nor choked, as supplied in YSK-857. The Speaker extension may or may not have a choke bead molded into the plug end, but not separately clipped around the wire. My point is that generic wiring can be substituted, provided the power supply and antenna cabling are installed appropriately.
    Cheers,
    David / N2PQW
ad: vanity
