Yaesu FT 891 Install And First Contact
Discussion in 'Amateur Radio News' started by WJ6F, Feb 23, 2017.
  1. HB9PJT
    HB9PJT Ham Member QRZ Page
    You have to push the tune button on the Tuner!
    I just made the cable to the Z-100Plus myself and it works as it should.
    SV1RXI and KF5VGK like this.
  2. AB3LI
    AB3LI Ham Member QRZ Page
    FT 891 TNR NOT ENGAGE WHEN PRESS ,SAME ISSUE HERE, I USE Z-100PLUS LGD TUNNER.ANY BODY KNOWS WHY OR HOW TO FIX IT.
  3. HB9PJT
    What menu settings did you do for the LDG tuner?
  4. AB3LI
    I use lamp but the tunner should engage ones you press tnr.
  5. AB3LI
    just hope that trew a firmware this can be resolve tnr should work with all ant tunners.
  6. HB9PJT
    That menu setting is fine. You have to press the tune button of the tuner that it works. The tune function of the TRX doesn't work. If it doesn't work that way, I would check the cable. Maybe the wiring is not correct.
    73, Peter - HB9PJT
