YAESU FT 757GXII Problema paso de sintonia
Discussion in 'Radio Circuits, Repair & Performance' started by LU3EFW, Oct 13, 2019.
  1. LU3EFW
    LU3EFW Ham Member QRZ Page
    Estimados, tengo un problema con el paso de sintonia de mi FT 757 GX II. No puedo volver al estado de sintonia de 10 khz, es como si la tecla Fast estuviera presionada. Esto ocurriĆ³ luego de realizar una soldadura sobre la pata 5 del conector del MIC, sin querer, con el equipo encendido. Esta falla se manifiesta tambiĆ©n sin el MIC colocado. Ya realice el reset con los botones posteriores sin tener resultado favorable al problema. Agradezco enormemente ayuda para poder resolver el problema.
  2. K9YLI
    K9YLI Ham Member QRZ Page
    from google translate... Don FYI
    Dear, I have a problem with the tuning step of my FT 757 GX II. I cannot return to the 10 kHz tuning state, it is as if the Fast key is pressed. This happened after welding on leg 5 of the MIC connector, unintentionally, with the equipment on. This fault also manifests without the MIC placed. Already reset with the subsequent buttons without having a favorable result to the problem. I greatly appreciate help in solving the problem.
