Yaesu FT-736R : Battery Replacement
Discussion in 'Radio Circuits, Repair & Performance' started by W9GB, Apr 30, 2020.
  1. W9GB
    USE Google ... Faster and shows photos/images.
    Discussed on QRZ Tech Forums : May 2015
    https://forums.qrz.com/index.php?th...battery-and-if-so-where-is-it-located.478318/
    REMOVE your FT-736R TOP COVER, you should SEE battery (photo below) on Control Board.
    Instructions in the FT-736R Service Manual,
    Drop Down the Front Panel to access the Control Board.
    332BC03B-0D80-4BEA-88C5-3D9D2C11F910.jpeg F191CE5B-E27B-48F6-9391-DD6DAD2618F9.jpeg
    The Yaesu FT-736R VHF/UHF transceiver used a Sony battery,
    BUT it is mounted vertically (solder tab mount) on the Front Panel/Display Board.
    Panasonic CR-2032/VCN (Digi-Key P660-ND) 17,178 in stock at $1.17 each.
    https://www.digikey.com/products/en/battery-products/batteries-non-rechargeable-primary/90?k=660-nd
    The Yaesu part number BQ041-22803 for the bulbs (incandescent lamps), was discontinued long ago. I DO NOT recommend LEDs, since the FT-736R uses “light pipe” plastic.
    The Yaesu 757GXII Owners Manual specifies that Yaesu part as an 8V 100 mA lamp fuse.
    While any low current, grain of wheat type lamp, from 6 to 8 volts, is a suitable replacement,
    its current rating must not exceed 100 mA.
    Bill Patton, WY3A (West Chester, PA) sells a suitable replacement lamp (6.5V, 68mA “grain of wheat” bulb) that are right size (T1) for Yaesu part #: BQ041-228038V 100 mA Lamp Fuse Bulb.
    Two (2) Bulbs for $8.25 Post Paid, while supplies last.
    http://www.qsl.net/wy3a/Lamp_Fuse.htm
    gb
    NS3L likes this.
  2. K6CLS
    K6CLS Ham Member QRZ Page
    ?? no question was asked about the bulbs ?? good to know anyway.
  3. W9GB
    Cliff -
    Despite multiple postings (my QRZ page) about NO Private Questions, I still receive these Tech Help Questions. Illiteracy is a growing problem (now estimated as 15% of American population).
    QRZ Tech Trolls (never Answer question, Self Promotion) scare many Beginners that Need Help from publicly posting QRZ Questions.
    I publicly Post their Question in the proper QRZ Tech Forum.
    I accidentally left out the Bulbs in Title, for this question ... and QRZ 30 minute Edit Window closed.
    gb
