Yaesu FL-2100f problem
Discussion in 'Amateur Radio Amplifiers' started by KB0UOA, Jun 27, 2015.
  1. KB0UOA
    KB0UOA XML Subscriber QRZ Page
    Im having a problem with my fl-2100f. The tubes are in transmit mode all the time. They get hot real fast. The amp goes into standby except for the tubes. An ideas?
  2. WW3QB
    WW3QB Ham Member QRZ Page
    Are you saying there is constant plate current? If yes, the bias may need adjusting. Are Svetlana brand 572B tubes installed?
  3. KB0UOA
    Yes, It has constant plate current. It has [FONT=arial, sans-serif]Centurion tubes. Is there a adjustment for bias?or just different resistors?[/FONT]
  4. WW3QB
    I assume you mean Cetron tubes. There is a large variable resistor (it is not a potentiometer) on the underside. But I fear you may have a bias circuit problem.
    Edit: Looking at the schematic the most likely failure is the bias electrolytic capacitor.
  5. KB0UOA
    Ok, Thanks
  6. WB2WIK
    Or the relay contacts that place the resistor in line on standby and short it out for operating.
  7. WW3QB
    What are you using to key the amp?
  8. KB0UOA
    Yaesu ft-101f
