Yaesu FL-2100b with slight hum
Discussion in 'Amateur Radio Amplifiers' started by W4MJR, Jan 22, 2019.
  1. N8FVJ
    N8FVJ Ham Member QRZ Page
    I have isolated transformers using rubber washers in-between the transformer and chassis. I assume the transformer laminations are tight. I have also tightened up the transformer screws on transformers with loose laminations and applied some lacquer to the laminations after tightening.
  2. F8BDX
    F8BDX Ham Member QRZ Page
    Hello
    me too the Transformer vibrates.
    I will look at this
  3. G3YRO
    G3YRO Ham Member QRZ Page
    Never had this hum vibration problem myself . . . but I would try tightening the bolts that go through the transformer.
    Also - I would not recommend modifying the bias circuit - the circuit in this amp never goes wrong . . . whereas the modified circuit used in the FL2100Z version fails all the time !
    Same goes for the Relay - it goes on forever . . . and not a problem unless you want to work break-in CW. And also don't change the anode stoppers.
    Roger G3YRO
  4. F8BDX
    the FL-2100 is ok.
    the problem was mechanical (fan)
    and the screws of the Transformer.
  5. F8BDX
    73 Roger
    Jose
