ad: Schulman-1
YAESU FL-2100B HOW TO REPLACE OPERATION SWITCH PILOT LIGHT
Discussion in 'Amateur Radio Amplifiers' started by WA4ALA, Sep 14, 2015.
  1. WA4ALA
    WA4ALA Premium Subscriber QRZ Page
    I hate to keep bothering this forum with questions concerning my ongoing efforts on the 2100B but I have nowhere else to go, having googled and checked all available documentation concerning how to replace a burned out pilot light for the operation switch on my 2100B.
    I can see that the light is housed in the switch but that is the extent of my information concerning this problem and I am reluctant to start taking this unit apart without a bit more information concerning the how and why of bulb replacement.
    Any and all help will be gratefully appreciated,
    73's,
    Michael - WA4ALA
  2. W9GB
    Fox-Tango is the base for Yaesu information, such as Yaesu "FL" amplifiers:
    http://foxtango.org/amplifiers/FL Amplifier Evolution.htm
    That pilot light scheme was used by Yaesu-Musen back in 1960s.
    Front cover removed.
    Yaesu FL-2100B --- TURN to Page 15 (Parts List)
    http://www.foxtango.org/ft-library/FT-Library/FT101/FL-2100B.pdf
    The Incadescent Lamps (PL, Pilot Lamp) are PL1 and PL2 : 14 Volts, 30 mA
    Bulb Size? Likely T-1 (3mm)
    Alltronics LP-23 is a T-1 bulb
    http://www.allelectronics.com/make-a-store/category/320200/lamps/incandescent/1.html
    BulbTown
    http://www.bulbtown.com/T3_4_T1_3_4...m?searching=Y&sort=13&cat=885&show=180&page=1
    Mouser
    http://www.mouser.com/Optoelectronics/Lamps-Holders/Lamps/_/N-5g6r
  3. WA4ALA
    Many thanks for all your help.
  4. G3YRO
    G3YRO Ham Member QRZ Page
    You can just use an ordinary 12V miniature bayonet bulb as used in cars - any motor accessory shop should have one (all car bulbs are designed to work at 14V)
  5. VE7GPG
    VE7GPG Ham Member QRZ Page
    A diode, a resistor, and a 12V led works just fine and won't burn out again
  6. G3YRO
    It's YEARS since I've worked on an FL2100 . . . but I'm pretty sure you can just replace the bulb from underneath (ie you don't have to take the front panel off or anything)
    Yes but a bulb plugs straight in and will last another 30 years!
    (Must confess I HATE LEDs used in cars for lighting!)
  7. VE7GPG
    True - but finding the correct size to fit the holder may be a problem - either way it's a quick fix !!
  8. K7DNA
    K7DNA Ham Member QRZ Page
    Late reply but might be useful. I've replaced the lamps in my FL-2100B with these Eiko #7646 bulbs. Same specs & size. Tinned the leads and used small shrink tubing. Works FB.
    Steve k7dna
