YAESU FL-2100B 10D1 Diode
Discussion in 'Amateur Radio Amplifiers' started by F8BDX, Jan 2, 2018.
  1. F8BDX
    F8BDX Ham Member QRZ Page
    Hello, and Happy New Year 2018 for all OM
    by which reference do these diodes replace?
    Tink you
  2. KD8DEY
    KD8DEY Ham Member QRZ Page
    Probably in the HV Bridge.....
    YMMV
  3. G3YRO
    G3YRO Ham Member QRZ Page
    You can just use 1N4007 . . . or if you want overkill, 1N5408.
    There is no need to have the 470k resistors across each one - these days, diodes are much more closely matched. So just remove them.
    Roger G3YRO
  4. F8BDX
    merci, 73
  5. F8BDX
    Hi 73 Georges
    it's for the Polarization Circuit
    1N4007 its good ???
    TNX
  6. G3YRO
    Not sure what you mean by Polarization Circuit . . .
    But a 1N4007 will be fine in ANY circuit that uses the 10D1
    Roger G3YRO
  7. F8BDX
    Hello Roger
    it's for the PB-1903 - BIAS CONT. BOARD.
    D301 to D305
    TNX 73
  8. KD8DEY
    Following..
  9. KD8DEY
    Dont see a listing for D301-305 in the schematic or parts list, But I do see D101-D110 listed in the HV section as 10D10....
    Et Tu?
    10D10
    1.5a @1K Piv,,,
    https://www.mouser.com/Semiconducto...uoc3dZ1yop3oa&Keyword=rectifier+diode&FS=True
    https://www.amazon.com/100-Pieces-1N5399-Rectifier-Electronic/dp/B079KB5VH5
    https://www.ebay.com/itm/20pcs-1N5399-1-5A-1000V-4-8W-Rectifier-Diode-chip-/381375008473
  10. WA7PRC
    WA7PRC Ham Member QRZ Page
    PB-1903 is used in the FL-2100Z, and is the bias & relay supply rectifier/filter PCB. The source is a 13V winding from power transformer PT1. Diodes D301 - D305 (pn 10D1, datasheet) are rated 1.5A @ 100V. Likely, the worst-case load current is well under 1.5A and any 1A rectifier (such as the common 1N4002-up) can be used.
